  1. I am using dvd flick and img burn to extract and convert a 4500 mb mkv to dvd. Even when I specify that the iso should be under 4300 mb so I can burn it, it always ends up being over. I also always get prompted to create a layerbreak.
    Probably easiest to try something else, like AVStoDVD. DVD Flick doesn't seem to be developed any longer.
  3. Ok thanks. Any idea why it is disregarding the file size I specify?
    Apr 2007
    Australia
    Do as you are doing then run the DVD files through DVDShrink. You'll get the size you want. It's an oldie but a goldie.
