Hi guys I use a lot of vhs capturing with virtual dub trough my TV card pinnacle 110i pro. The problem that I have is since I upgrade to windows 7 (64 or 32 its the same problem) when I try to use the levels tab (some way of hardware proc amp controls for tv card itself in virtual dub) in vdub capture menu where there is colour contrast brightness and sharpness sliders they are greyed out and it says that they are not available with this driver. The interesting thing is that this doesn’t happen in vista or in xp only in windows 7. And if I use the same driver that I install in vista the same thing ( so I think it is not driver issue but the OS problem). That’s why I am using double boot PC with vista and windows 7. Does someone have the same problem or have some solution or tweak in windows 7 to resolve this issue.
Thanks Jagabo. Isn't there any hack that can do this because vista and windows 7 are very similar if not equal as far as I know and the problem only exist in windows 7
If I knew a fix I would have given it. If you find a workaround please let everyone know.
capture card with proc-amp capabilities
By smartel in forum Newbie / General discussionsReplies: 17Last Post: 25th Mar 2013, 23:27 -
Using VirtualDub's "capture filter" proc amp
By sanlyn in forum Capturing and VCRReplies: 3Last Post: 31st Jan 2012, 08:13 -
Proc Amp like Filters & settings
By themaster1 in forum RestorationReplies: 2Last Post: 25th Aug 2008, 13:01 -
Capture card with 50 and 60Hz Mode
By nintendo in forum Capturing and VCRReplies: 8Last Post: 4th Jun 2008, 06:46 -
Proc amp? Fix levels at input to Canpus ADVC110
By 2Bdecided in forum Capturing and VCRReplies: 16Last Post: 3rd Jun 2008, 11:31
