Page 2 of 2
FirstFirst 1 2
Results 31 to 48 of 48
  1. Try this: DePulse(h=74, l=12, d=255, debug=true) but i prefer the DvDropout script which work temporally (analysis of the next frame) and spatially indeed so it's for video only, not a single frame.
    The debug mode in Depulse is very useful it show you if you're off the mark or not
    Jul 2009
    Spain
    Depulse is a spatio-temporal filter too (using both previous and next frames).
  3. Originally Posted by Gavino View Post
    Add this line before calling DePulse:
    ConvertToYUY2()
    Then I get Script error: ConvertToYUY2 does not have a named argument "h"
    or, if your source is interlaced YV12:
    ConvertToYUY2(interlaced=true)
    This one actually opens and plays video in both screens but I don't see any difference. Both are filled with "comets". BTW is he saving 'restored' video somewhere?
    I get again that YUY2 parameters are missing
    Would it maybe help if I shared sample 1 minute of this video and you could tell me what to write?
    Jun 2004
    Ferrara-Italia
    Hi,
    You need the converttoyuy2(interlaced=true) line in your script because that's what depulse expects as input, i.e. if you feed it anything but yuy2, it will throw an error. All the converttoyuy2(interlaced=true) line does is convert the input clip's colorspace to yuy2 (look up yuy2, yv12 and the other colorspaces if you're not familiar with these terms).
    After you've converted to yuy2 you may use depulse:
    avisource("youfile.avi")
    converttoyuy2(interlaced=true) #assuming the file is REALLY interlaced
    depulse() #insert depulse's parameters between ()
    And no, the video at this point is not saved anywhere, avisynth just passes (it is a "frameserver") the frames to any appplication that works with it, you could say it's a "virtual video" at this stage. To save the video you will have to open the .avs file you've created in an encoding application or video editor of your choice and render as a new file. If you tell us what your final format is (DVD, PC playback, NMT playback, web upload etc...), the people here will advise you on what type of encoder is suitable for your needs.
    Sorry, I had to go see about a girl
  5. Originally Posted by midnightsun View Post
    With arguments to DePulse::
    Or if the file isn't interlaced:
    converttoyuy2()
  6. OK, so from what I gather I first need to convert the vid to yuy2 by writing command
    So I made .avs file with those lines and I opened it in virtualdub and clicked save segmented avi. Then, if I understand correctly, I should that saved video run with commands
    I did but I got video that looks like this
    I still have those 'comets' but they are violet along with some other parts of the picture.
    I then tried with this commands
    converttoyuy2()
    and I still get this violet result.
    my desired final format would be .avi. So if you can also tell me how to save the file from virtualdub so it doesn't get that big.
  7. Don't use "debug=true" if you want to fix your video. That's just to make it obvious what DePulse() is going to fix. With all those large purple areas you're going to have to play with the other settings.
  8. Originally Posted by jagabo View Post
    You mean to change variables h, l, d ? Could you tell me what each stands for?
    Because I was playing with them and entered this:
    converttoyuy2() #assuming the file is REALLY interlaced
    DePulse(h=135, l=30, d=255, debug=true)
    And there is no violet exept for the "comets" that are violet:
    Jul 2009
    Spain
    See http://forum.doom9.org/showthread.php?p=1355414#post1355414:
    Pixel brightness values greater than h (high) are targeted as white noise.
        If a pixel (t) is target'ed as white noise then surrounding pixels
        (above, below, before and after [temporal], Not left and right) are tested
        and if ALL of them are less than (t - d) the target pixel t is
        depulsed.
    Pixel brightness values less than l (low) are targeted as black noise.
        If a pixel (t) is target'ed as black noise then surrounding pixels
        (above, below, before and after [temporal], Not left and right) are tested and
        if ALL of them are greater than (t + d) the target pixel t is
        depulsed.
    In debug mode, pixels judged to be black or white noise are coloured pink or green.
    It looks like some parts of your comets are still showing white, so you might need to tweak the parameters just a little more.
  10. OK thanks for the info, but I don't want those "bad" pixels or "comets" to be green or violet I want them to be inconspicuous.
    Jul 2009
    Spain
    The idea is that you use Depulse with debug=true to tweak the other parameters until only the bad pixels are coloured green or violet. That shows you which pixels Depulse is going to fix. Then to do the actual work, you change debug to false and run the script again for the last time.
  12. OK thanks I think I got it. It's just that now I have problem saving video in virtualdub. It's too big. I searched on the internet and all tuts that I find say that you have to click "Video" and set "Direct Stream Copy" and then "Save as AVI". I do this but it's still BIG. I mean it's starts saving and when it's on 29 seconds it's already 456 MB.
  13. Originally Posted by Lucky Starr View Post
    You need to select a compression codec and adjust its settings.
    Jul 2009
    Spain
    You don't use Direct Stream Copy when using Avisynth, since it delivers uncompressed video.
    Use Fast Recompress instead (and select a compression codec as jagabo says).
  15. OK it cleaned it pretty good from those 'comets' thanks for the help!
    But there is also another problem that happened during VHS to wmv conversion (I was using honestech program) and the problem is that picture frequently but briefly becomes "linear" when there are fast movements or switching between shots. Like this
    Is there any cure for this? Would it be better if I captured VHS with VirtualDub?
  16. You have interlaced video, probably telecined film (if it's a movie). It needs to be deinterlaced or inverse telecined if you want a progressive picture. Without seeing an actual video sample I can't say which. Try this in VirtualDub:
    Video -> Color Depth... 4:2:2 YCbCr (YUY2)
    Video -> Filters -> Add -> IVTC... Reduce Frame Rate, Top Field First, Adaptive
    If you still see comb artifacts try Bottom Field First.
  17. WMV don't support interlacing but progressive only to my knowledge so you either have to deinterlace on the fly (wrong idea imo) or post capture stage
  18. WMV does support interlaced video, at least with the VC1 codec. Many applications don't support interlaced VC1 in WMV though.
