Results 1 to 30 of 48
  1. Thanks to everybody (especially jagabo) who introduced me to AviSynth and HC Encoder in a previous thread and helped me to get them working (I wanted to deblock the video). It's really opened my eyes to what's possible for video improvement. I thought stuff like that was only available to studios!
    I have 15 year old VHS wrestling tapes which were converted to DVD. I would like to improve the picture quality and I would like the colours to be better. They're a bit dull. I need to change the picture function on my TV from Natural to Cinema to get better colours but they still aren't great. The black levels seem OK though. This is the script I used:
    Mpeg2Source("I:\New\1 = Test files\clip 704.d2v", CPU=6)
    AddBorders(8, 0, 8, 0)
    McTemporalDenoise(settings="medium", interlaced=true)
    The "CPU=6" is the maximum deblocking setting.
    I've added the borders because I'm converting 704 x 480 to 720 x 480.
    That script pretty much eliminated the Blocking (pixilation), the Gaussian noise (it's like grain all over the picture), the Mosquito noise (like grain on the edge of objects), and it gave better black levels. But is there anything else I could improve?
    I've also uploaded a 20 second DVD ISO HERE. I would be grateful if someone could burn the ISO to a DVD and watch it on your TV via a HDMI cable so you could tell me if there's any part of the picture I could improve with a script. That video is preferable as a video looks different on a TV and PC monitor. Or if you prefer to view it on your PC I've uploaded the M2V video that I created with my script HERE.
    Please suggest scripts which you think would improve my video (I don't care how long the scripts take to make a video). I've also included my HC Encoder settings below in case you think I could use better settings:
Name:	Settings for HC Encoder.jpg
    I saw the power of AviSynth videos such as this: http://vimeo.com/11133342. It looks like the video was unblurred so it looks like a DVD. Are there any filters that can do that with VHS videos which were transferred to DVD?
    By the way, what is deringing?
  2. The black levels still look too high for me. I think there's a little too much noise reduction too. Everything looks like plastic. I'd try stepping McTemporalDenoise() down to low. Or denoise only the chroma channels:
    MergeChroma(last, McTemporalDenoise(settings="high", interlaced=true))
    Deringing removes the mosquito noise around sharp edges. It's ringing from the DCT compression. See figure 4:
    http://www.waset.org/journals/waset/v13/v13-51.pdf
    Wow! When you perform an image search for "DCT ringing" at google some of my posts are at the top:
    https://forum.videohelp.com/threads/314708-Good-quality-What-changes-could-be-made?p=19...=1#post1946534
    https://forum.videohelp.com/threads/294144-Viewing-tests-and-sample-files?p=1792973&vie...=1#post1792973
  3. What do you mean by too high?
    Just an update. Like I said before this is the script I used.
    However I asked my question before it finished converting the video. It took 6 hours just to get to 19% completion! So I can't use the above script.Instead I need a script that will take less than 5 hours which will do the same as the above script.
    I've uploaded my original 20 second video HERE or ideally you could download the ISO HERE and burn it to a DVD to see what it looks like on your TV.
    I currently do deblocking like this which takes about 1 hour 26 minutes
    Could someone please tell me what script I could use which would do the same as this:
    Off the top of the my head this is what I need:
    • Screen flicker removed
    • Mosquito noise around the edges of objects removed
    • Better black levels and colours
    So if someone could suggest the script I need to do that or anything else I could use to improve the picture (as long as it takes under 5 hours) I would be grateful.
  4. Try adding ColorYUV(cont_y=24,off_y=-12). That's probably a decent compromise for the clip. Or ColorYUV(autogain=true) (you'll have to crop away the black borders first, add them back later). It's a bit aggressive for my taste though. Maybe you could follow it with ColorYUV(gain_y=-8), something like that.
    For faster noise removal look at fft3d(), TTempSmooth(), DegrainMedian(), any of the 3d smoothers. But leave a little of the grain in the video. It will reduce the posterization -- especially noticeable in the black/gray background.
  5. Originally Posted by jagabo View Post
    Could you please suggest a script which contains all of that as I don't know what settings to use?
    Should I still have this at the top of my file?:
    Mpeg2Source("I:\New\1 = Test files\Dec 30 original test file.d2v", CPU=6)
    If I were to use ColorYUV(autogain=true) should I put that above my borders code? Should the borders code always be used last?
    Also just wondering what you meant by the black levels being too high. Does that mean they are too black?
  6. Without the AddBorders() there's still a bit of black at the left edge. That's probably not enough to confuse ColorYUV's autogain feature. But if it does you'll have to crop that away too. Then add borders back later.
    I don't do a lot of noise reduction myself. For all those other filters you can read the docs as well as I can. You can also search through posts here looking for examples.
    Try using Deen(). The default settings might be OK. If not, try changing thry and thruv.
  7. Hi
    I'm not sure if you don't bother to read a little bit about VHS restoration here at Videohelp.
    If it helps, take a look at
    https://forum.videohelp.com/threads/322848-Scripts-and-filters-for-an-Opera-%28sample-v...os-included%29
    This is a long thread about scripts for restoration a very damaged video.
    Thank you.
  8. You need to learn to use Historgram(). And CSamp is a very useful tool.
  9. Thanks for your help.
  10. I currently use this to denoise my videos:
    However McTemporalDenoise takes over 20 hours with a 1 hour 15 minute file. Is there any script which will perform the same function as the above McTemporalDenoise script which takes 3 hours or less?
  11. Could someone please suggest a script that will fix the colours along with hue, saturation, brightness, and contrast and anything else like that and good white and black levels. Some files have dull colours, others are fine. I need a script which I can use on any of my videos which will normalize the colours so they look normal on all my videos. If the colours are already fine in some of the videos then the script should have no effect. Would the following script do that?: ColorYUV(autogain=true)
    What exactly is luma and chroma by the way?
    The script must take 3 hours or less with a 1 hour 15 minute file.
  12. The picture in some of my videos moves up and down every several seconds. Is there any way to fix that with a script? If so, could you please advise the best script to use.
  13. I already use this script which deblocks and removes the noise but it doesn't increase the picture quality.
    I know there are scripts that sharpen the picture but I don't know which to use and what script I should use.
  14. For noise reduction you can try TTempSmooth() and fft3dfilter(). There are several threads around here with examples. They're a lot faster than MCTD.
  15. If you're using a slow filter stack with an intended 2pass encode, it's often faster to apply the filters use a lossless intermediate, then feed that intermediate into the final encoder . The reason is the slow filters are endured once instead of twice.
  16. Originally Posted by jagabo View Post
    I tried fft3dfilter with the default options but it didn't look as good as this McTemporalDenoise. I didn't really understand the fft3dfilter author's instructions. Could you please point me to one of those threads you mentioned or give me a script which will achieve the same as this (but faster):
    Also when you said to use ColorYUV(autogain=true), will that have no effect against a video who's colours are already correct?
  17. Originally Posted by poisondeathray View Post
    I have no idea what that means!
  18. Originally Posted by holygamer View Post
    That is not correct. Not every shot in a video is supposed to use the full range of luma values. For example a dark shot may have no bright areas at all. Autogain will brighten up a shot like that because it blindly tries to adjust the histogram to use the entire luma range. It doesn't know that shot is supposed to be dark.
  19. Originally Posted by jagabo View Post
    OK, it's just that I've got loads of videos and I don't want to have to manually check to see which ones don't have the correct colours. Is there any script I can use which is similar to ColorYUV(autogain=true) that I can use on all my videos. So that when the colours need fixing, it fixes them and when they don't need fixing it doens't fix them (or it does but the colours look the same as before)?
  20. Originally Posted by holygamer View Post
    No.
  21. Member hydra3333's Avatar
    Oct 2009
    Australia
    thought of
    Mpeg2Source("I:\New\1 = Test files\Dec 30 original test file.d2v", CPU=6) with
    Mdegrain1 or Mdegrain2 - http://avisynth.org.ru/fizick.html
    HDRAGC - auto gain control https://forum.videohelp.com/threads/258407-HDR-AGC-Filter-lighten-dark-footage
  22. Banned
    New York, US
    If you don't know what those terms mean, you're at a serious disadvantage working with AviSynth filters (or any color/levels filters, for that matter). A small part of this can be explained by a doom9 tutorial on post-processing in AviSynth:
    http://www.doom9.org/capture/postprocessing_avisynth.html
    A similar tutorial exists for VirtualDub, which many use for video correction and restoration:
    http://www.doom9.org/capture/postprocessing_vdub.html
    But those articles might still be a bit difficult. IF you're going to clean up and improve tape sources (especially sources already subject to noise and some data loss by conversion to DVD), you can expect to spend much more than 3 hours on a 1-hr 15-min tape. Many members here could help by posting scripts for particular scenes, but no single script will work for every scene or every video.
  23. Take a scene with normal lighting conditions (outdoor scene ) take a black scene analyse both with the histogram and fix the levels, that'll be a good beginning for a good overall black/white levels imo.
    Fix the levels with Ylevels (see doom9 forum) which is an improved version of the levels filter
  24. I recently transferred some older VHS tape to digital and the picture has scratchings on it like this:
    I mean it may look like just three scratchings but it's just on one picture and multiply it with 24 pics a sec and you get rather a distracting annoyance. So I was wondering if there was maybe a software that automatically fixes those things by let's say comparing it to the previous or next picture? Would AviSynth help with this?
  25. see here (best solution imo) lucky star
    see also here
  26. It looks like the DePulse() filter is specifically designed to remove those "comets". I downloaded it for the next time I have some video with that problem.
  27. Ok thank you very much for support! First of all I must say this program is giving me a headache since I never worked with "text" program like this. I guess I'll need some time to get around it. DePulse filter option seems like promising solution and I managed to find and download it although it doesn't seem to be listed on that wiki plugins page.
  28. http://avisynth.org/mediawiki/Getting_started
    Put the DePulse.dll file in AviSynth's plugins folder and it will load automatically whenever you open an AviSynth script. Your script will look something like:
    AviSource("filename.avi")
    DePulse()
    Open that with any encoder that supports AviSynth script. Like VirtualDub.
  29. OK thanks! I'll try doing something around it.
    EDIT: This is what I wrote
    AviSource("k:\Converting\name of the video.avi")
    DePulse()
    and saved it as .avs
    But when I tried opening it in virtualdub it said it can't because: "depulse: requiers yuy2 imput" - so what now?
    EDIT 2: hmm I found syntax on doom9 forum and it goes:
    DePulse(clip, h=180[0-255], l=60[0-255], d=30[0-255], debug=false[true/false])
    but when i try to open it in virtualdub I get error message saying: Unexpected character: "["
  30. Member
    Jul 2009
    Spain
    Add this line before calling DePulse:
    ConvertToYUY2()
    or, if your source is interlaced YV12:
    ConvertToYUY2(interlaced=true)
    The "[...]" is not part of the syntax, it's an addition in the documentation to show the range of possible values for the parameters, eg h can be anything from 0 to 255. So you would just write, for, example,
    DePulse(h=180, l=60, d=30, debug=false)
    You don't need to supply parameters if the defaults are satisfactory.
    (In fact, the values shown here are the defaults.)
    Note that the clip input parameter defaults to the result of the last filter used.
