I bought a new Samsung BD-D6500 player in US at Best Buy. As it is for region 1, I need to hack for all regions.
I have follow the instructions of BD-D5500 to hack the BD-D6500. However the remote control does not have the button REPEAT!!
Any can help me on that? What button in the remote control should substitute REPEAT one?
Thanks!
				Results 1 to 12 of 12
	The hack probably won't work. We've had a report of exactly ONE Samsung BluRay player sold in the USA that can be made region free. I don't remember what it was, but I do remember the poster said that the hack worked exactly as it was written. Almost all Samsung hacks are for Australian players.
 If by some miracle you get this to work for you, do understand that it will make the player region free ONLY for DVD playback and not for BluRay playback.
	Thanks. Re blue ray playback I don't have problems, once my region is the same of US.
 I need to hack the DVD playback! I would like to try the post, but I don't find the REPEAT button in the remote control. My question is if someone knows what is the equivalent button in the new remote control of Samsung.
 Thanks again!
	Similar experience with Samsung BDD6500 bought in US October '11. Hack won't work because there's no REPEAT key. I like the unit very much so far (bought it yesterday) -- its only shortcoming is not being region free. I too would appreciate suggestions if anyone has one.
 Noting JMAN98's comments, I'm not optimistic. But I'd ask: are there some brands that usually ARE amenable to region-free hacks?
	Philips and Pioneer models are may still be hackable and I've seen reports that suggest that Insignia may be hackable too. However I cannot personally confirm any of those hacks on BluRay players. Typically hacks on BluRay players only make them region free for DVD playback.
 You can't buy their models in stores like Best Buy, but Oppo players are supposed to still be hackable for DVD and BluRay playback. Their models require a hardware modification for this that either you or the seller will have to do to make the player region free.
	I must thank 'mxm' in the Whirlpool forum for this solution. It does work (on 2nd attempt for me).
 I know that I started the 'repeat' 7 6 8 8 4 process whilst the blue light was still on during the "press eject button".
 Whether that helped or not, who knows? In any case, I was very happy to see the '4' appear in the top right of the TV screen.
 To quote 'mxm. ...
 Just confirming this does work for DVDs, so good news. The instructions for the bd d5500 didn't quite apply since there isn't a physical tray. This is what I did and it worked:
 1. Ensure there is no disk in the player
 2. Turn off and turn on the player (clean boot)
 3. Wait for the menu to appear on your tv
 Now this is a bit tricky, you'll have to be quick, you'll probably have to try a couple of times.
 4. press the eject button (on the remote or on the display)
 5. press the eject button again
 6. on your remote, in one smooth motion, press 'repeat' 7 6 8 8 4
 7. As soon as you see the '4' appear on the top right of your tv, press 9.
 Your player is now region free for DVDs. Enjoy! Please note: as you've probably found all over the web, this works for Australian players, most likely not for others.
	My remote control doens´t have the "REPEAT" button. Any idea? Thanks!
  Samsung BD-D6500 Region Free FirmwareBy adam177 in forum DVD & Blu-ray PlayersReplies: 6Last Post: 13th Mar 2012, 01:03
  Samsung BD-D6500 Region CodeBy mikey321 in forum DVD & Blu-ray PlayersReplies: 7Last Post: 7th Feb 2012, 13:28
  Samsung D530 Hack Codes neededBy LihomWon in forum DVD & Blu-ray PlayersReplies: 0Last Post: 8th Oct 2011, 03:49
  Samsung HT-C450/XEU & Samsung BD-C5300 hacks/codes neededBy raindancerob in forum DVD & Blu-ray PlayersReplies: 8Last Post: 5th Mar 2011, 11:45
  Multi Region / Region Free codesBy Flying_Dragon in forum DVD & Blu-ray PlayersReplies: 2Last Post: 19th Jan 2009, 09:10
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
