I'm a big fan of TMPGEnc software and back in the day I used to use TMPGEnc Plus all the time for all my video conversions and joining video files.
Lately I have been converting alot of AVI files to DVD format which have worked very well, but their lays a question which someoneo might be able to help me figure it out properly.
My current method of going from an AVI to DVD is the following;
I open the AVi file in TMPGEnc Xpress and convert the file to an compliant dvd standard format in .MPG, I then open TMGEnc Authoring Works 4 and open the MPG to author it to DVD file structure. My question is, would it be possible to exclude TMPGEnc Xpress altogether and simply use TMPGEnc Authoring Works 4 to open the AVI file and encode it to DVD file structure directly?
I've done it before, and it saves me about 8 minutes in processing time and just wanted to know if im doing basic converting to DVD will it affect the quality of the avi whatsoever? Can i just simply use it and avoid xpress 4 as the middle man? thanks
Yep, you can use tmpgenc authoring works directly. It uses the same encoder as in tmpgenc xpress.
Thanks for the reply Baldrick, but I forgot to mention that when attempting to go through TMPGEnc Authoring Works directly their seems to be an audio delay, where-as when using the TMPG Xpress and then Authoring works it does it perfectly fine.
I think that was what caused me to keep using the TMPGenc Xpress all this time because now that I remember correctly it causes an out of sync issue, any ideas??
Problem capturing audio with most programs, any fixes? + Lagless programs?
By fgsfdsyo in forum Capturing and VCRReplies: 5Last Post: 15th Oct 2009, 16:51 -
Tmpgenc dvd author 3 will not author my m2v files????
By biged670 in forum Authoring (DVD)Replies: 1Last Post: 28th Sep 2009, 11:10 -
Does Tmpg Divx Author encode or it only author ?
By BlackShadow90 in forum Authoring (DVD)Replies: 3Last Post: 29th Jul 2008, 03:56 -
Any Programs Do This?
By sj022698 in forum Newbie / General discussionsReplies: 3Last Post: 5th Feb 2008, 17:39 -
DVD Codecs and Author Programs
By ChrisXP in forum Newbie / General discussionsReplies: 4Last Post: 2nd Oct 2007, 12:52
