Results 1 to 1 of 1
  1. When I start to encode a DVD title to H.264 using MEncoder and x264, MEncoder outputs the following:
    Could not find matching colorspace - retrying with -vf scale...
    Opening video filter: [scale]
    The selected video_out device is incompatible with this codec.
    Try appending the scale filter to your filter list,
    e.g. -vf spp,scale instead of -vf spp.
    but it continues to encode without any problem and the encoded stream looks properly encoded.
    Theese are the parameters I use in MEncoder for the first pass:
    mencoder vobfile.vob -vf crop=704:464:12:8,yadif,hqdn3d -nosound -ovc x264 -x264encopts threads=auto:pass=1:profile=high:bitrate=1220:preset=slower -of rawvideo -o /dev/null
    and the second pass:
    mencoder vobfile.vob -vf crop=704:464:12:8,yadif,hqdn3d -nosound -ovc x264 -x264encopts threads=auto:pass=2:profile=high:bitrate=1220:preset=slower -of rawvideo -o encodedstream.264
    But even if I append the scale filter to the above parameters, like MEncoder tells me:
    mencoder vobfile.vob -vf crop=704:464:12:8,yadif,hqdn3d,scale
    then MEncoder still outputs the same message as it does when I don't append the scale filter to the filter list:
    This is what the scale filter does (it's from mencoder's manual):
    scale[=w:h[:interlaced[:chr_drop[:par[:par2[:presize[:noup[:arnd]]]]]]]]
    Scales the image with the software scaler (slow) and performs a YUV<−>RGB colorspace conversion
    From this, I understand that it converts the source frames to RBG before sending them to x264, but I don't know if this conversion is necesary, therefore, I don't know if the scale filter is needed, but even if I add it, mencoder tells me to add it.
