Hello my dear friends,
Let me explain my problem.
I need a software which can cut desired number of seconds from the beginning of the movie AND works in direct mode (without recompression).
I want to remove advertisement from the beginning
Apparently VirtualDub cannot do this exactly as I wantfor example when I want to cut first 7 seconds it cuts less of them and leaves few frames.
So, VirtualDub cuts but not exact number of frames I want.
Is that a bug?
I haven't checked if that bug happens also in Full Processing mode; if anyone know please tell me tow to resolve this.
Alternatively, I could replace this advert with black frames but I don't know how to.
Thanks!!
The bug is not in VirtualDub; it is an inherent issue with long GOP (Group of Pictures) video streams. You say NOTHING about the type of video file you have, but from the nature of your complaint, my guess is Xvid avi.
When dealing with videos that are compressed into GOPs, you can only cut on I-frames in direct mode. -
That's right, I am trying with xvid avi.
I see your point.
But what about Full Processing mode? Can I cut exact number of frames in this mode? -
Make sure you have the latest version of VirtualDub. Use Smart Rendering to render only the needed frames around the edit point, while maintaining Direct Stream copy around the remainder of the video. You may also need to use Cut Assistant to navigate to the exact frame.
Virtualdub 32bits error: cannot connect to the desired capture driver!
By Cauptain in forum Capturing and VCRReplies: 3Last Post: 21st May 2011, 12:17 -
Megui only processing 1/3 the number of frames
By capvid0429 in forum Video ConversionReplies: 1Last Post: 3rd Jan 2011, 20:28 -
Count number of frames in AVI
By p.w in forum Video ConversionReplies: 10Last Post: 8th Mar 2010, 09:13 -
VirtualDub: "The audio codec cannot compress the source to the desired
By user2008 in forum Capturing and VCRReplies: 6Last Post: 12th Jun 2009, 20:35 -
Burn a DVD - Number of Frames error
By p_uriel in forum Video ConversionReplies: 5Last Post: 21st May 2008, 19:07
