After I encode a MPEG-2 video stream to H.264, using MEncoder and x264, I get a raw .264 video stream, and I want to open this .264 stream and a .ac3 stream in mkvmerge for muxing, but mkvmerge cannot read information from .264 streams, like FPS. My question is, should I just specify the FPS manually in mkvmerge, or is it better to mux the .264 into a .MP4 container first, an then open the .mp4 in mkvmerge so that mkvmerge can detect all info needed ?
in a guide to mkvmerge gui, it says:
but some ppl still mux the .264 to .mp4, before muxing to .mkvFPS: Number of frames per second for AVC/h.264 video tracks. When you add AVC/h.264 elementary streams then mkvmerge must be told which how many frames per second this video was recorded with because that piece of information is not available in elementary streams. If you don't select anything then mkvmerge defaults to 25. You can either enter a floating point number (e.g. 29.97) or a fraction (e.g. 30000/1001).
This option is only available for AVC/h.264 video tracks read from AVC/h.264 elementary streams.
anyway, it seems that muxing .264 to .mp4 before muxing to mkv, is unnecessary, so i'll just open the .264 in mkvmerge gui and specify it's FPS
MkvТоMp4 v0.224 - rapid tool for repack Mkv to Mp4
By oreons in forum Video ConversionReplies: 808Last Post: 7th Mar 2022, 02:43 -
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 12:19 -
How to convert an h.264 MKV with softsubs to an h.264 MP4 with hardsubs.
By hawk16zz in forum User guidesReplies: 4Last Post: 27th Apr 2010, 12:41 -
MKV (h.264 file) conversion to AVI or MP4
By killwill169 in forum MacReplies: 43Last Post: 12th Aug 2009, 19:35 -
Converting .avi (Xvid) to .mp4 or .mkv (H.264 or x.264) w/ subs
By Tensai in forum Video ConversionReplies: 4Last Post: 18th Jul 2007, 10:25
