Hi Friends,
I have some old important VCDs. In those Video is in .DAT format. I have saved them at my computer. Now I want to write them in video DVD so dvd can be played at DVD players. I am using Nero 7 for burning DVD but it only allows .VOB, .BUP and .IFO files. Can someone please explain the process, how can I burn dat to video DVD.
I have the idea that I may need to change dat file to vob etc.. format. but which software I should use for this. there are bunch of softwares and most of them are trial version over the web. please suggest. also after conversion to vob.., would I be able to burn a dvd video from that..
Please help as I know there are lot of experts in this field at this website.
Many thanks
Abhishek
DVD Ripping? Nope, moving you to our dvd authoring section.
You can try a free dvd authoring app like DVD Flick or DVD Styler or commercial apps like Tmpgenc Authoring works. Just add the dat and it will make a DVD-Video(vob/ifo). If they refuse to load the dat then convert the dat to standard mpg with vcdgear. -
Thanks Baldrick for this. I will check them out. is it possible to use Nero7 also anyhow so the resultant video quality should also be good..
How to create the file structure of a DVD video disc?
By mrpop151 in forum Authoring (DVD)Replies: 2Last Post: 16th Nov 2009, 12:51 -
How do I create a continous MPEG2 file from a DVD with video from menus
By porchmonkey in forum Authoring (DVD)Replies: 3Last Post: 5th May 2009, 06:48 -
Video dat file played only like audio file
By newbievideohelp in forum Software PlayingReplies: 9Last Post: 14th Oct 2008, 20:31 -
How to descryption video.dat file.
By newbievideohelp in forum ProgrammingReplies: 1Last Post: 12th Oct 2008, 23:11 -
AVSEQ.DAT file -video cd can't copy and play
By desiboy1436 in forum Authoring (VCD/SVCD)Replies: 12Last Post: 17th Jul 2008, 11:43
