This is my first time using these forums, but I know you folks may be able to help. I have an old personal video of my kid in an MTV format, is there anyway to convert it into anything but mtv? Nothing I have now can play the dang file. HELP, I have searched these forums top to bottom with no answer in sight.
Results 1 to 9 of 9
If ffmpeg's ffplay can play it you should be able to use ffmpegsource() in an AviSynth script top open it. You could then save it to some other format using the editor and codecs of your choice. AviSynth is something of and advanced topic though.
Note the page I linked to has links to more information including transcoding tools.
How big is the file? Can you upload it? -
I've attempted to use that but I am not that advanced at using such tools. and the file is much too big, about 128 mb
No suitable decoder module: VLC does not support the audio or video format "undf". Unfortunately there is no way for you to fix this.
Seems there are two types of MTV files, those created for or by vlc and those by an older coby conversion software. quote:
"There is a different distinct type of MTV file being produced by another utility called "MTV Video Converter" which has version numbers 1.x The most recent version I've been able to locate is v1.12.11 and this utility produces much smaller files, ~1.2Mbpm but they aren't viewable with VLC at all."
Format Factory problem
By Stef2010 in forum Video ConversionReplies: 6Last Post: 29th May 2012, 16:31 -
Sound card problem(Windows 7 user)
By ppeterr in forum AudioReplies: 10Last Post: 18th Jan 2010, 07:18 -
Banned user for suggesting "format C: /y"
By stiltman in forum FeedbackReplies: 91Last Post: 9th Nov 2009, 10:43 -
problem with mpg format
By volam in forum EditingReplies: 0Last Post: 17th May 2009, 14:31 -
Problem with QuickTime - DV Format
By parisisal in forum Software PlayingReplies: 3Last Post: 10th Mar 2009, 10:56
