I bought this Acer Aspire 5250-BZ873 for my daughter. http://www.acer.it/ac/en/US/content/model/LX.RJY02.004
Now I want to upgrade RAM.
I've removed 2 screws from the memory compartment cover, but I still cannot remove it.
Does anyone know how to remove memory compartment cover on this model, please?
Thank you in advance.
P.S.
In the meantime I've received this answer from Acer:
"Acer does not provide any instructions to end users regarding assembling/disassembling the computer."
I've solved the problem myself.
There are 2 screws which have to be removed, but the cover still sits firmly in place because of small plastic catches around the rim of the cover.
These catches are engaged in small recesses around the rim of the housing. A small screwdriver has to be used to carefully pry those catches out of its recesses and the cover can be removed. So, I've upgraded the RAM with additional and compatible 2GB DDR3-1333 memory module (Skill). Works fine.
The same procedure of removing the memory cover works on series 5750 and 5742 of Acer Aspire, because the chassis seems to be the same.
Need 12 cell battery for Acer Aspire One ZG5
By V Bot in forum ComputerReplies: 4Last Post: 18th Feb 2011, 16:14 -
Acer Aspire Wlan
By didikai in forum Video ConversionReplies: 2Last Post: 19th Nov 2010, 18:44 -
Acer Aspire ???
By HotDamn! in forum ComputerReplies: 11Last Post: 19th Apr 2010, 12:07 -
WIFI Problems on ACER ASPIRE 5920G
By Damned4eternity in forum ComputerReplies: 5Last Post: 18th Aug 2009, 12:21 -
Acer Aspire 5920G WLAN Keeps Disconnecting
By Squid_uk in forum ComputerReplies: 14Last Post: 21st Aug 2008, 18:34
