We'll I've ripped all the movies using AnyDVD HD, but when I convert them using Ripbot the subtitles that translate what characters like Jabba say into english are missing.
Does anyone have any clue how I can include them? Not really interested in all the subs, just the translation ones
Any help would be appreciated
Almost certainly forced subs embedded in one of the subtitle streams. Now, you can either keep all English subs (easiest and the space required is negligible) or identify and extract the forced subs with BDSup2Sub and remux them. I haven't used RipBot enough to advise you on that.
Good luck and welcome to the forum.Pull! Bang! Darn! -
are they M2tS files.. your star wars films? or are they MKV?
coz if they're MKV files just download MKVtoolnix (free) and the alien subs off torrent (or subscene.com) and then open the mkvMERGEgui and open your MKV, add the subttitle and click REMUX.. a few mins later you will have your movie with correct subs..
and you can even remove all other subs/ lang
if it's an M2Ts there is a gui for this too. you can extract
trying to copy Star Wars to blu ray
By vbstein in forum Blu-ray RippingReplies: 8Last Post: 12th Feb 2012, 08:53 -
help with star wars saga br
By kn5150 in forum Blu-ray RippingReplies: 9Last Post: 21st Sep 2011, 17:55 -
Lucas Confirms : Star Wars saga to be relkeased on Bluray 2011
By guns1inger in forum Off topicReplies: 6Last Post: 8th Sep 2010, 10:25 -
Forced subtitles english Blu Ray Avatar
By Modify_inc in forum Newbie / General discussionsReplies: 1Last Post: 26th Apr 2010, 23:31 -
Diff languages in Star Wars conversion.
By neomaine in forum DVD RippingReplies: 0Last Post: 5th Feb 2008, 09:06
