  1. Ok here goes.
    I have an xbox 360 S-Video/AV Cable.
    I have a capture card which has a Pinnacle Studio Moviebox 510 USB Video Capture Device (view here: http://www.it-echo.com/2010/03/19/pinnacle-studio-moviebox-510-usb-video-capture-device-reviews.html)
    I have a standard def tv with composite inputs.
    I want to know, can I connect my xbox using the same S-Video/AV Cable having the av outputs on the cable connect to my tv and the svideo cable connect to my capture device and be able to play the game on the tv AT THE SAME TIME that my capture device records the output from the S-Video output. Is dual screen even possible with xbox 360?
    If anyone has any experience with this please let me know how to make this happen.
    Thanks!
  2. does anyone know what the settings on the xbox would be?
  3. in case anyone was stumped, yes it does work.
