Hello,
Over the years (from XP to Win 7 64) my codecs/filters went south...
Nowadays tools like Subtitle Workshop are not showing video anymore.
Is there a way I could "clean" the PC and reinstall a new set of codec/ filters?
Thanks for your help,
Did Subtitle Workshop ever work for you in Win 7 64? I had to install Subtitle Creator in the XP virtual machine that came with my copy of Win 7 Ultimate as I could not get it to work directly under Win 7. I've had a few other programs that I could only get to work under the XP virtual machine.
Thanks, guys
When I moved from XP ot 7 64, Subtilte Workshop was fine with AVi or MPG files, not so with MKV ones. I don't know if it was related to the MKV format or the H.264 video (I had audio but no video).
Tried to fix the codec/filters (Codec Tweak, fixes & reset settings), now I only have audio independent of file type. That's why of this post.
I will take a look at Subtitle Creator. A quick test of Easy Subtitles Synchronizer is promising. Easy Subtitle uses VLC and not PC codecs.
Problem with mkv files in mpc-hc after reinstalling windows
By ronlut in forum Software PlayingReplies: 17Last Post: 19th Apr 2012, 00:56 -
Reinstalling Windows XP
By wulf109 in forum ComputerReplies: 17Last Post: 2nd Apr 2012, 18:52 -
Help getting the correct codecs/filters
By TheFrostyC in forum Newbie / General discussionsReplies: 9Last Post: 22nd Jan 2011, 05:26 -
Need help on reinstalling ffmpegX after removing the program on my computer
By DDieggo1000 in forum ffmpegX general discussionReplies: 1Last Post: 28th May 2009, 13:49 -
Reinstalling windows vista
By Sportster Freak in forum Newbie / General discussionsReplies: 2Last Post: 17th Mar 2009, 22:23
