    Feb 2009
    India
    I have am mkv files which has 3 languages used in it. The main audio is English. There are a whole lot of conversational passages which are either in French or Vietnamese.
    There are 2 English language srt files. One is ONLY for the English speech part. The other one is ONLY for the English translation of French and Vietnamese speech parts. Naturally the time codes overlap.
    I would like to MERGE the two so that I have both the English speech as well as the English translations appear on the screen at the right moment.
    I know I can go the copy paste route and renumbering each segment but that would take hours. Wondering if any software can do this me!
    Any and all help / suggestions welcome.
    Last edited by pmshah; 19th Sep 2011 at 01:07. Reason: spelling correction in title.
    I haven't seen such a feature in a subtitle editor.
    But you can use a software player that shows several subtitles, like kmplayer.
  3. Explorer Case's Avatar
    Feb 2004
    Middle Earth
    Jubler can fix time inconsistencies, by re-sorting the subtitle lines.
    Add one file to the other using copy-paste in a text editor first. Open in Jubler. Select the first line by clicking on it. Shift-click the last line. Now all should be selected. Menu > Tools > Time fix > Sort first; de-select other options (or use the Sort button). Save.
    The time codes for every subtitle line should now be in chronological order.
    Feb 2009
    India
    Thanks Baldrick and Case.
    I will try out both options. I hope Kmplayer compares well to VLC.
