How do I best sync 2 mkv file???
The first file is in Full HD but the audio is jap. The second file is in 360p and with eng audio.
Now I want the have the best from both file so i get a file in Full HD with eng audio.
If i play the 2 files at the same time they are at the same point at the same time and they continues to be that.
playtime for file 1 is 0:24:39
playtime for file 2 is 0:24:40
I have tried to split video and audio and then join them together again but they are not sync
Hope you people can help me
Results 1 to 10 of 10
After remuxing, in what way is the sync off? Are they off by the same amount throughout the video? Do they start in sync then get further and further out of sync as the video progresses? Do they start out in sync then suddently get out of sync at some point? Maybe several times during the video?
It start in sync then get further and further out of sync as the video progresses.
Du you have a solutions? -
The easiest fix is to change the video frame rate when you mux the two together. MMG will allow you to flag a different frame rate. That might cause a little jerk in the video every now and then. And some players may not pay attention to the flagged frame rate. The harder fix is to open the audio in an audio editor, adjust the length, recompress it, then mux with the video. Audacity has audio stretch/shrink filters.
Did you include the ffmpeg import plugin? It may be able to import your audio after that:
http://manual.audacityteam.org/man/FAQ:Installation_and_Plug-Ins#How_do_I_download_and...ort_Library.3F
Then use File -> Import -> Audio...
To change running time:
Effect -> Change Speed (changes pitch)
Effect -> Change Tempo (doesn't change pitch) -
Thanks for the help. It has really useful, but i got one last question.
Do you know what to do if I encounter the last problem, with the audio getting out of several times during the video? or is it just a waste of time to fix that? -
It's going to be a lot of work. You have two different cuts of the movie. You'll have to figure out where scenes were added or cut then adjust the audio to match. It's probably too hard to do with Audacity. You'll need to use a good video editor that lets you make those kinds of changes to the audio.
Fixing sound sync issues in a mkv file
By Psykro in forum EditingReplies: 12Last Post: 20th Dec 2014, 11:31 -
video file and subtitles file are out of sync because of missing intro
By bmaya in forum SubtitleReplies: 3Last Post: 13th May 2010, 11:26 -
video file out of sync after 20 minutes
By snafubaby in forum Newbie / General discussionsReplies: 1Last Post: 21st Feb 2009, 04:21 -
alltoMKV converted MKV file sound out of sync.
By necrobutcher in forum Video ConversionReplies: 1Last Post: 10th Jun 2008, 17:25 -
Need to expand sound file to fix sync problems
By Calidore in forum AudioReplies: 0Last Post: 5th Jul 2007, 16:53
