Without thinking about it I made a number of ISOs from DVDs on one of my hard disks that I had moved the contents out of the VIDEO_TS folder. So, I now have a number of ISOs with the proper contents but they're not inside a TS folder.
They play fine, but without chapters. To redo them I have been reconverting them to files(vobs and ifos) with 7zFM.
This only takes a few min each. Putting the contents into a VIDEO_TS folder and reconverting back to an ISO but this time within the TS folder.
Is there an easier way to do this?
Tony
Well, that's what I thought too. I was hoping that maybe IMGBURN had a simple way to do it.
It only takes 3 min to do the whole process with one ISO but I have to do about 40 of them.
It's not difficult to do but as soon as you have to do the some thing more than 3 or 4 times...you say... or at least I do..There must be an app. for that.
But if it's not free and since I'll never make that mistake again. I guess I'll just do it the old fashioned way.
Can you mount an .ISO image to a hard drive , then copy the VIDEO_TS folder
By Bansaw in forum Newbie / General discussionsReplies: 8Last Post: 19th Jul 2011, 19:11 -
Burning DVD with VIDEO_TS Folder
By bguguen in forum MacReplies: 7Last Post: 28th Jul 2009, 01:10 -
Avi->DVD no Video_TS folder
By gaikoku in forum ffmpegX general discussionReplies: 7Last Post: 13th Sep 2008, 13:11 -
Using Nero Ultra: How Do I Use Video_TS Folder ---> DVD
By MacPCConsultants in forum Newbie / General discussionsReplies: 6Last Post: 28th Nov 2007, 07:16 -
VLC - plays DVD from video_ts folder?
By qpskfec in forum Software PlayingReplies: 9Last Post: 21st Nov 2007, 14:38
