So....
Captured on my windows machine (Lenovo T61 laptop 2GB ram) using Virtual Dub around 7 and 1/2 minutes of video and audio using the Huffy Codec. Obviously was preseted with a MASSIVE file (7.3 GB). THis is old material 4:3 aspect ratio. Easycap device btw. That file is fine, audio late by around 750ms but nothing that can't be fixed.
I've now transferred this to this machine (Ubuntu 11.04, 1.75GHzx2, 2GB, 250GB drive) and have been trying to compression into a reasonable size. Also I'd like this to be in a endoced form that a standard Windows 7 PC can use. Using AVIDEMUX (V2.5.4) and have installed ffmpeg.
However, AVIDEMUX is regularly crashing. Also on the odd occasions when it does seem to work I get a file that Movie Player doesn't like.
Any ideas??
 http://www.kiva.org/about
	Need more definition of what comes next? Will you be editing on the PC? If so keep it Huffy or convert to DV or high bit rate MPeg2.
 DVD?
 Youtube?
 archive?[/QUOTE]
 Well firstly it will be used in a PowerPoint presentation (so I wondered if a wmv version would be best??), but I'd like to put this on a DVD for "posterity", but thanks for coming back at what is probably a regular question on here!!
	Well, if you need any edit stuff (cut, crop, color correction, etc...) Keep it in HuffYuv and do everything you need using Virtualdub/Avisynth/Premiere or what you like more...
 When you are ready to archive try directly command line ffmpeg, it can probably do anything you need (mp4, wmv, mpeg2 etc).
 Don't worry about lower cpu... it's probably gonna take double or three times of video length...
 My suggestion for archive is mp4 (H.264/AAC) deinterlaced, with square pixel (640x480, 768x576), with CRF 21 or 22.
 Don't know about PowerPoint, probably wmv is the right way... but not sure...
 elmuz
  x264 Compression brightness/contrast issuesBy SavageStyle in forum Video ConversionReplies: 43Last Post: 29th Sep 2011, 23:03
  Capture analogue (eg. VHS, analogue camcorder) - AVI or MPEG?By ManUtdFans in forum Capturing and VCRReplies: 3Last Post: 18th Jan 2009, 19:29
  Caller ID softwareBy 1234567 in forum ComputerReplies: 15Last Post: 8th Oct 2008, 17:32
  Issues with google video/compressionBy AlasdairMac in forum Newbie / General discussionsReplies: 4Last Post: 15th May 2008, 11:38
  Date & Time Captured by DV out of Video CameraBy Mazen in forum Capturing and VCRReplies: 17Last Post: 13th Oct 2007, 11:00
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
