My Blu ray player is a LG BD550.
Im using a WD1TB USB External Hard Drive that connects to the USB port to play .avi and .mkv files.
Certain files play fine on both avi and mkv.
However certain 1080p mkv files dont play while others do. On the ones that wont play I get a message saying "this movie may not play properly", however it plays fine on my laptop.
Ive done a bit of reading about it and have remuxed it to disable header removal compression for audio and video tracks by default.
On Episode 1 of Band of Brothers this worked, however on the 2nd episode it didn't.
Ive put both files into media info to see if there is any difference with the files:
and Episode 2General
Unique ID :202817418428781202066081059065688005134 (0x989536C4BDB6F55EB25B500BCF309A0E)
Complete name :C:\Users\Laptop\Desktop\Episode 1 (1).mkv
Format : Matroska
Format version : Version 2
File size : 6.56 GiB
Duration : 1h 13mn
Overall bit rate : 12.8 Mbps
Encoded date : UTC 2011-09-16 22:41:08
Writing application : mkvmerge v4.9.1 ('Ich will')built on Jul 11 2011 23:53:15
Writing library : libebml v1.2.1 +libmatroska v1.1.1
Video
Format : AVC
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 1h 13mn
Bit rate : 10.9 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.220
Stream size : 5.46 GiB (83%)
Writing library : x264 core 65 r1029M cb3c213
Encoding settings : cabac=1 / ref=4 /deblock=1:-2:-1 / analyse=0x3:0x113 / me=umh / subme=6 / psy_rd=1.0:0.0 /mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 /deadzone=21,11 / chroma_qp_offset=-2 / threads=6 / nr=0 / decimate=1 / mbaff=0/ bframes=16 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=3 / wpredb=1 /keyint=250 / keyint_min=25 / scenecut=40(pre) / rc=2pass / bitrate=10943 /ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 /qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:1.00
Language : English
Audio #1
Format : DTS
Format/Info : Digital Theater Systems
Codec ID : A_DTS
Duration : 1h 13mn
Bit rate mode : Constant
Bit rate : 1 510 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Compression mode : Lossy
Stream size : 791 MiB (12%)
Title : eng
Language : English
Audio #2
Format : AC-3
Format/Info : Audio Coding 3
Codec ID : A_AC3
Duration : 1h 13mn
Bit rate : 384 Kbps
Bit depth : 16 bits
Stream size : 201 MiB (3%)
Title : 国语
Language : Chinese
General
Unique ID :221319570168213684286967065279083612468 (0xA680994774D3C91DAACB45AAEC9C8934)
Complete name :C:\Users\Laptop\Desktop\Episode 5.mkv
Format : Matroska
Format version : Version 1
Duration : 55mn 42s
Overall bit rate : 16.9 Mbps
Encoded date : UTC 2008-12-08 05:12:30
Writing application : mkvmerge v2.2.0 ('Turn It OnAgain') built on Mar 4 2008 12:58:26
Writing library : libebml v0.7.7 +libmatroska v0.8.1
Video
Format : AVC
Format profile : High@L5.1
Format settings, ReFrames : 8 frames
Duration : 55mn 42s
Bit rate : 15.0 Mbps
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.301
Stream size : 5.69 GiB (87%)
Encoding settings : cabac=1 / ref=8 /deblock=1:-2:-1 / analyse=0x3:0x113 / me=umh / subme=6 / psy_rd=1.0:0.0 /mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 /deadzone=21,11 / chroma_qp_offset=-2 / threads=6 / nr=0 / decimate=1 / mbaff=0/ bframes=16 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=3 / wpredb=1 /keyint=250 / keyint_min=25 / scenecut=40(pre) / rc=2pass / bitrate=14983 /ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 /qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:1.00
Language : English
Audio #1
Format : DTS
Codec ID : A_DTS
Duration : 55mn 42s
Bit depth : 16 bits
Stream size : 602 MiB (9%)
Title : eng
Language : English
Audio #2
Format : AC-3
Codec ID : A_AC3
Duration : 55mn 42s
Bit rate : 384 Kbps
Bit depth : 16 bits
Stream size : 153 MiB (2%)
Title : 国语
Language : Chinese
Can anyone help to see what the difference is between the 2 files? My guess is that the files are 2 different ones inside the mkv container and my Blu Ray player can play one type and not the other.
The LG BD550 can play other 1080p mkv files fine.
Results 1 to 16 of 16
For #2 , L5.1 is problematic, likely the reason . Most hardware chips only support high@L4.1 or lower
Format profile : High@L5.1 -
Just checked a sample of Star Wars 1080p
Again the Format profile is High@L4.1. This mkv works so it must be this.General
Unique ID : 180557583677431400741794489911472842234 (0x87D6202E780041E0B74DD52A2C6C65FA)
Complete name : C:\Users\Laptop\Desktop\Star.Wars.1977-1983.BluRay.1080p.DTSES6.1 2Audio.x264-CHD\Star.Wars.Episode.4.A.New.Hope.1977.BluRay.108 0p.DTSES6.1.2Audio.x264-CHD\sample.mkv
Format : Matroska
File size : 101 MiB
Duration : 45s 726ms
Overall bit rate : 18.5 Mbps
Encoded date : UTC 2011-08-30 01:32:21
Writing application : mkvmerge v3.2.0 ('Beginnings') 编译于 Feb 12 2010 16:46:17
Writing library : libebml v0.7.9 + libmatroska v0.8.1
Video
Format : AVC
Format settings, ReFrames : 5 frames
Duration : 45s 712ms
Bit rate : 16.5 Mbps
Height : 816 pixels
Display aspect ratio : 2.35:1
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.438
Stream size : 89.7 MiB (89%)
Title : Star.Wars.Episode.4.A.New.Hope.1977
Language : English
Audio #1
Format : DTS
Format profile : ES
Codec ID : A_DTS
Channel(s) : 7 channels / 6 channels
Channel positions : Front: L C R, Side: L R, Back: C, LFE / Front: L C R, Side: L R, LFE
Bit depth : 24 bits
Delay relative to video : 51ms
Stream size : 8.23 MiB (8%)
Title : DTS-CORE ES6.1 1536K
Language : English
Audio #2
Format : AC-3
Codec ID : A_AC3
Bit rate : 192 Kbps
Channel(s) : 2 channels
Bit depth : 16 bits
Delay relative to video : 30ms
Stream size : 1.05 MiB (1%)
Title : DD2.0 192K
Language : Chinese
Is there anyway I can re-encode a file to make it high@L4.1? -
Thank You for the help because it was the format.
Fo anyone reading this in the future with the same problem you can use http://coolsoft.altervista.org/h264leveleditor to change the level and put it to 4.1. mkv's are working fine now.
Thanks -
Got the file working so making progress but the picture is now suffering from Pixelation.
Any ideas? -
just changing the text in the file to @4.1 doesn't change the video from @5.1 - for that you need to re-encode it.
Ok thanks, Ill have a search around on what is best to re encode the file to 4.1
I bet more than 4 re-frames on a 1080p video is the problem. You have to re-encode to change that.
my lg 570 and 670 can handle 5 reframes.
So I will need a full re-encode of the mkv file? Will it lose qaulity?
This one wouldnt play at all until changed it to 4.1. plays fine now despite it being 8 frames too and no Pixelation
General
Unique ID : 229799830465160644162561093545414835033 (0xACE1D6647C717E03BF8AF936D3FF3B59)
Complete name : G:\Movies\Blu Ray\1080p\Star Wars 1080p\Episode IV - A New Hope.mkv
Format : Matroska
File size : 7.95 GiB
Duration : 1h 59mn
Overall bit rate : 9 513 Kbps
Encoded date : UTC 2007-09-01 15:40:45
Writing application : mkvmerge v2.0.2 ('You're My Flame') built on Feb 21 2007 23:40:55
Writing library : libebml v0.7.7 + libmatroska v0.8.1
Video
Format : AVC
Duration : 1h 59mn
Bit rate : 9 126 Kbps
Height : 816 pixels
Frame rate : 25.000 fps
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.233
Stream size : 7.47 GiB (94%)
Writing library : x264 core 56 svn-667C
Encoding settings : cabac=1 / ref=5 / deblock=1:-4:-4 / analyse=0x3:0x133 / me=umh / subme=6 / brdo=1 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=2 / deadzone=4,6 / chroma_qp_offset=0 / threads=3 / nr=0 / decimate=1 / mbaff=0 / bframes=3 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=3 / wpredb=1 / bime=1 / keyint=250 / keyint_min=25 / scenecut=40(pre) / rc=2pass / bitrate=9126 / ratetol=1.0 / rceq='blurCplx^(1-qComp)' / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 / zones=173169,179370,b=0.15 / aq=1:0.3:15.0
Language : English
Audio
Format : AC-3
Codec ID : A_AC3
Duration : 1h 59mn
Bit rate : 384 Kbps
Bit depth : 16 bits
Stream size : 328 MiB (4%)
Language : English
Text
Format : UTF-8
Codec ID : S_TEXT/UTF8
Codec ID/Info : UTF-8 Plain Text
Language : English -
By accident i found out, the video timings weren't correct. You can fix this with mkvtoolnix, by selecting the video stream and on the rightside select rewrite video timings.
No Netcast option in LG BD550, how to install it?
By chilenomaldito in forum DVD & Blu-ray PlayersReplies: 11Last Post: 9th Feb 2013, 07:32 -
problems splitting mkv files then playing on lg blu ray
By julie_152 in forum Video ConversionReplies: 6Last Post: 15th Jan 2013, 05:54 -
lg bd550
By sassi in forum Latest Video NewsReplies: 1Last Post: 1st May 2011, 04:46 -
LG BD550 - MKV playback Issues
By Khalua in forum DVD & Blu-ray PlayersReplies: 5Last Post: 18th Apr 2011, 09:52 -
Problems playing MKV 720 & 1080 - Not enough PC ?
By NotSoEasy in forum Software PlayingReplies: 8Last Post: 7th May 2010, 12:30
