Hi! I have a cable box in my living room, and we put a splitter to run just basic cable without a box into the other rooms. All the channels work great except one channel on each of the added TVs doesn't work now. Does anyone have any idea what we did wrong or how to fix it? Thanks in advance!
Results 1 to 10 of 10
There is another possibility. The signal for the missing channel is a little weaker than the others, and once split and attenuated further by a longer cable run, it is too weak to tune. I have seen that happen myself.
That was my thought as well. The OP doesn't say if its digital or analogue cable, but if the digital signal is on the limit anyway, it would be more susceptible to a drop in signal level if a non powered splitter was used.
If the splitter is a powered device, it might be that the unused outputs are unterminated. Not sure how much of an impact this has on the signal in practice, but I remember reading about it when installing my loft distribution system. I didn't bother to terminate the outputs though... -
We have digital cable, and it's a non-powered splitter, so I guess that's the problem. We're pretty low-tech and consistently about a decade behind the times around here
Thank you all for your input!
@txmt
Is it an analog channel and what is the channel number? -
In one room, Oxygen Channel doesn't come in at all and CBS is fuzzy. I think it might be a different channel in another room. I'll check in the morning
Please give the cannel numbers. Some older TV's don't recieve the higher cable channels.
Composite cable splitter
By danielmak in forum Capturing and VCRReplies: 4Last Post: 8th May 2011, 04:12 -
TOSHIBA D-R7. Problem with quality of coax cable.
By caddyfleet in forum DVD & Blu-ray RecordersReplies: 6Last Post: 5th Feb 2010, 19:01 -
Thin or flat coax cable....does it work ok?
By hygieneboy in forum Off topicReplies: 4Last Post: 29th Aug 2009, 21:28 -
Should I invest in a 2ghz coax splitter for a cable modem?
By yoda313 in forum ComputerReplies: 4Last Post: 23rd May 2009, 08:06 -
HDMI cable splitter
By snadge in forum DVB / IPTVReplies: 6Last Post: 21st Feb 2009, 10:24
