Hello!!
I just need a small part of an AVI video, but I don't know how to cut a selection from the original AVI file
Maybe someone could help me?
Many thanks!!
VirtualDub and VirtualDubMod can also do this, but in my opinion it's not very intuitive. There are guides on the internet that tell you how to do it and it's not difficult, but I never would have known how to do it without a guide.
May thanks, but the thing is: I already have got avidemux, but I don't know why, there is nos sound when I open the AVI file to cut... Not easy to do the right selection without sound...
And for the other programs, I'm working on Mac...
You would need to find out what format the audio is in. I'm guessing it might be one AVIDemux doesn't recognize. You should also be aware that highly compressed AVI formats can only be cut on keyframes (I frames) if you want to avoid video and sync problems. But keyframes can be widely spaced on some of those formats, so frame accurate cuts are difficult.
For cutting instructions with AVIDemux see this: http://www.avidemux.org/admWiki/doku.php?id=using:cutting
I should also mention that 'AVI' is just a generic container name. Many, many, formats can be called AVI.
Cut part of High Definition Video
By Bruno AUgusto in forum EditingReplies: 4Last Post: 15th Nov 2011, 09:20 -
How to cut a 3gp video file to part files without a reencode?
By kop in forum EditingReplies: 2Last Post: 20th Oct 2008, 14:33 -
By kop in forum Portable VideoReplies: 1Last Post: 20th Oct 2008, 02:16 -
Having trouble starting video at a certain spot, to cut out a part
By snafubaby in forum Newbie / General discussionsReplies: 3Last Post: 23rd Jun 2008, 08:03 -
How cut part of .flv video?
By method in forum Newbie / General discussionsReplies: 9Last Post: 9th Nov 2007, 09:31
