Page 2 of 2
FirstFirst 1 2
Results 31 to 42 of 42
  1. Member goodiesguy's Avatar
    Sep 2011
    New Zealand
    Script Error: Invalid arguments to Function "DoubleFPS".
    Line 14
  2. Beware this message board inserts bizarre spaces, so be careful if you're copying & pasting scripts
    For example, go look at your post #22 , there is a huge gap where there shouldn't be on line 14. Make sure your actual script doesn't have that space. Another example, "Hullabal oo" has a space inserted
    https://forum.videohelp.com/threads/339017-Motion-Interpolation-%28VidFIRE%29-Software?...=1#post2154058
    Jul 2009
    Spain
    That's only on the display - the underlying text is actually OK.
    That's because you have wrongly added a '60' to jagabo's original script.
    DoubleFPS(60)
    The last part of the script should be
    DirectShowSource("C:\Users\Nathan\Desktop\Hullabaloo_Dec 6, 1965.avi")
    DoubleFPS()
    SeparateFields()
    SelectEvery(4,0,3)
    Weave()
    Actually, it would be better to use AviSource than DirectShowSource, which is not always frame-accurate.
  4. Member goodiesguy's Avatar
    Sep 2011
    New Zealand
    function DoubleFPS(clip source)
    super = MSuper(source, pel=2, hpad=0, vpad=0, rfilter=4)
    backward_1 = MAnalyse(super, chroma=false, isb=true, blksize=16, searchparam=3, plevel=0, search=3, badrange=(-24))
    forward_1 = MAnalyse(super, chroma=false, isb=false, blksize=16, searchparam=3, plevel=0, search=3, badrange=(-24))
    backward_2 = MRecalculate(super, chroma=false, backward_1, blksize=8, searchparam=1, search=3)
    forward_2 = MRecalculate(super, chroma=false, forward_1, blksize=8, searchparam=1, search=3)
    backward_3 = MRecalculate(super, chroma=false, backward_2, blksize=4, searchparam=0, search=3)
    forward_3 = MRecalculate(super, chroma=false, forward_2, blksize=4, searchparam=0, search=3)
    MBlockFps(source, super, backward_3, forward_3, num=2*FramerateNumerator(source), den=FramerateDenominator(source),
    mode=0)
    DirectShowSource("C:\Users\Nathan\Desktop\Hullabal oo_Dec 6, 1965.avi")
    DoubleFPS()
    SeparateFields()
    SelectEvery(4,0,3)
    Weave()
    This is my script now. It is now saying there is no MSuper and errors on line 3 and 14.
    Jul 2009
    Spain
    MSuper is part of MVTools.
    As already said by others, you need to copy mvtools2.dll into the Avisynth plugins folder.
    Incidentally, the first line number (3) is the one where the error really is.
    If an error occurs inside a function, Avisynth also provides a traceback showing where that function was called from - here DoubleFPS called on line 14.
  6. sorry to dig up this old thread...but i am also interested in getting this script to open in virtualdub..
    this is script i'm using..
    function DoubleFPS("clip source")
    mode=0)
    DirectShowSource("C:\Users\demo\Desktop\ed.avi")
    DoubleFPS()
    SeparateFields()
    SelectEvery(4,0,3)
    Weave()
    this is error message....any help appreciated
  7. "mode=0)" on line 10 should be at the end of the previous line. And remove the quotes around "clip source" on the first line.
  8. scrap last message...my error
    Image Attached Images
  9. Did you make the change I suggested for the first line? What does it read now?
    i did....it now loads the video.....but thats about it tbh, i exported to an avi file but that looks the same & is 25 fps .not 50
    probably doing something wrong my side.......not on my pc as i type this.......
  11. You script changes from 25p to 25i. Both are 25 frames per second. But the latter has interlaced frames. If you want 50p remove the last three lines.
    thanks....
