I have a stand alone DVD/CD player in my home theater. I like to play CD in "shuffle" mode so it's not in the order the CD comes in. I put the 4 CD's on one CD in MP3 format. I found my DVD/CD Player doesn't Shuffle MP3 Discs.
The only way I can think of is to put the 4 CD's in CD format on a DVD. This way it would be in the format that does play in shuffle mode.
Is this possible to do?
Thank you,
Chris.
Try StreamFab Downloader and download from Netflix, Amazon, Youtube! Or Try DVDFab and copy Blu-rays!
CD format isn't allowed on DVD discs. I don't know of any program that will let you do that. I would try this on a rewritable DVD first, but it may be possible to get shuffle play if you rip the 4 CDs to WAV files (this is lossless by the way) and burn those WAV files to a DVD as a data disc. If that doesn't work then I would conclude that the manufacturer of your system simply only supports shuffle play for regular audio CDs and nothing else.
Try this http://www.audio-dvd-creator.com/
Desparetly wanted the default op codes for a LG RHT378H Dvd recorder.
By bert123 in forum DVD & Blu-ray RecordersReplies: 1Last Post: 11th Feb 2012, 04:34 -
wanted DVD to MKV that works
By jack616 in forum DVD RippingReplies: 2Last Post: 29th Nov 2011, 09:42 -
Recommendation wanted for DVD recorder in USA
By jman98 in forum DVD & Blu-ray RecordersReplies: 4Last Post: 15th Jul 2011, 13:46 -
JVC SR-MV40 Video to DVD Instructions Wanted
By Trishymouse in forum Newbie / General discussionsReplies: 0Last Post: 11th Jul 2007, 13:10 -
Hack wanted! Samsung DVD R-119
By StewyW in forum Newbie / General discussionsReplies: 0Last Post: 14th Jun 2007, 12:31
