Cant compress STAR WARS BDs and with ayumi hamasaki COUNTDOWN LIVE 2010-2011 A ~do it again~.... i'm getting this error
or this error- [10:07:32] Reencoding audio tracks (if req'd)
- ERROR preparing intermediate audio.
- [10:07:33] - Failed to reencode audio, aborted
Whats the problem???- [17:11:36] Reencoding audio tracks (if req'd)
- [17:11:36] Multiplexing M2TS
- Error in attempt to multiplex: MUX_00500.meta
- H.264 stream does not contain fps field. Muxing fps=23.976
[17:11:38] - Failed to build structure, aborted
what codec pack do you recommend i need to Use?
when i do the INSPECT of codec of BDrebuilder i get this allways
- Windows Version: 6.1 [7601]
- AVISYNTH Version: 2.5.8.0, Ok
- HAALI Splitter: Isn't recommended version
- FFDSHOW: 3951, not recommended version
- WIN7 preferred AVC CODEC: Ok
- WIN7 preferred VC-1 CODEC: Ok
- WIN7 preferred MPEG2 CODEC: Ok
- FFDSHOW VC-1 set incorrectly: [0]
- FFDSHOW MPEG2 set incorrectly: [0]
- FFDSHOW AVC set to "libavcodec": Ok
- BD Rebuilder v0.39.0.1, Ok
- X264: Ok
- AFTEN: Ok
- FAAC: Ok
- MP4BOX: Ok
- WAVI: Ok
- TSMUXER: Ok
tried to use CCCP codecs, Matroska pack and Klite
help..........
Closed Thread
Results 1 to 14 of 14
You should use only AviSynth, ffdshow and Haali. Codec packs are a crapshoot, you may get away with it, but they can cause a lot of trouble.
Uninstall your codec pack(s) and use the tested versions linked here:
http://forum.doom9.org/showthread.php?t=143716
I suspect Haali is the main problem, but the other settings should be like this:
FFDSHOW VC-1 should be set to WMV9
Set FFDSHOW MPEG2 to libmpeg2
Set FFDSHOW AVC to ffmpeg-mt
Go to ffdshow video decoder configuration. Click codecs. Find, for instance, VC-1 and click the decoder used. A drop-down list will appear, select the correct decoder and apply. Repeat for anything else inspect.exe tells you is wrong.
Good luck.Pull! Bang! Darn!
no luck
still getting this error with Star Wars BDs
[20:35:49] BD Rebuilder v0.39.01 (beta)
- Source: STAR_WARS_EPISODE_V_THE_EMPIRE_STRIKES_BACK
- Input BD size: 39,36 GB
- Approximate total content: [02:37:22.306]
- Target BD size: 23,83 GB
- Auto Quality: Good (Very Fast), ABR
- Audio Settings: AC3=0 DTS=0 HD=0 Kbs=640
[20:35:51] PHASE ONE, Encoding
- [20:35:51] Processing: VID_00500 (1 of 10)
- [20:35:51] Extracting A/V streams [VID_00500]
- [20:35:51] Reencoding video [VID_00500]
- Source Video: MPEG-4 (AVC), 1920x1080
- Rate/Length: 23,976fps, 3.510 frames
- Bitrate: 500 Kbs
- [20:35:51] Reencoding: VID_00500, Pass 1 of 1
- [20:35:54] Video Encode complete
- [20:35:54] Reencoding audio tracks (if req'd)
- [20:35:54] Multiplexing M2TS
[20:35:57] - Failed to build structure, aborted
It would help if you gave some useful information.
Such as: Did you uninstall any codec packs? Did you install recommended versions of the helper apps? Does inspect.exe say everything is okay now? Have you *ever* been able to successfully rebuild a Blu-Ray with BDRB or is this your first go?
Your configuration must be screwed. I think if it were BDRB's fault, there'd be some mention of problems with the Star Wars BDs in the BDRB bug report thread.
I guess I'll break down and buy the BD set of the Star Wars series, but I don't have it to test at the moment.Pull! Bang! Darn!
- Yes I unistalled all codec packs and install the recomended codec 1 by 1
- Inspect.exe says all is OK
- Yes I have compressed many blurays without a problem, yesturday I compressed without problem BACK HAWK DOWN
- but Whit ayumi hamasaki COUNTDOWN LIVE 2010-2011 A ~do it again~ and Star Wars Ep 5 (i havent downloaded the rest yet) I can't compress them, don't know why?
- can it be that there still some protection so BDRebulder give me this error?????
Maybe I've missed it somewhere, but what are you using for decryption? If you are using DVDFab Passkey or AnyDVD HD, have you ripped the entire blu ray disk to the hard drive first, before trying to compress with BD Rebuilder?
help with star wars saga br
By kn5150 in forum Blu-ray RippingReplies: 9Last Post: 21st Sep 2011, 17:55 -
More changes to Star Wars in Bluray editions
By yoda313 in forum Off topicReplies: 12Last Post: 18th Sep 2011, 17:15 -
Star Wars 3D
By stiltman in forum Off topicReplies: 20Last Post: 26th Oct 2010, 20:11 -
Dancing with the Star Wars stars!
By freebird73717 in forum Off topicReplies: 0Last Post: 22nd Nov 2008, 20:55 -
Star Wars: The Legacy Revealed
By JimmyJoeBob in forum Off topicReplies: 3Last Post: 1st Jun 2007, 19:14
