For instance in the script you gave for StillCher...ColorYUV(cont_u=-26, cont_v=-26) the "-26" would make the yellow more blue and the red more green? So if I wanted to do do the opposite then it would look like: ColorYUV(cont_u=26, cont_v=26) as positive numbers?
Results 181 to 189 of 189
I strongly suggest you use avspmod to learn what each setting is doing. This way you can configure the settings to your own tastes
Add histogram("levels") to the bottom of the script while you are making coloryuv settings changes , this will show the graph of Y, U, and V
As soon as you make a change, hit f5 to refresh the preview, make another adjustment, hit f5 again....rinse & repeat
Watch how the image changes, and watch how the graph changes. This is how you will learn what is going on -
function int2mode(int index) { return Select(index, "classic", "levels", "color") } #for HISTOGRAM
Function TestFunction(int index) { return Select(index, "Placebo", "Very Slow", "Slower", "Slow", "Medium", "Fast", "Faster", "Very Fast", "Super Fast", "Ultra Fast", "Draft") } # for QTGMC with UserSlider
AVISource("C:\StillCher2.avi")
AssumeTFF()
separatefields()
converttoyv12(interlaced=false)
input=last
Ylevels(16, 1.000, 235, 0, 255)
###### COLOR CORRECTION: HUE, SATURATION, INTENSITY (RGB) ############
ConverttoRGB32(matrix="rec601",interlaced=false)
LoadVirtualdubplugin("C:\Program Files\VirtualDubMod\plugins\Hue.vdf", "hsi",1)
# Infos: Red's complementary is Cyan / Green's complementary is Magenta / Blue's complementary is Yellow
# Change the first value (Hue) according to your needs), don't change anything exept Hue according to my tests
hsi(-1, 1, 15, 0, 1) # Red (primary color)
hsi(-1, 1, 13, 0, 4) # Bue (primary color)
hsi(0, 1, 9, 0, 2) # Green (primary color)
hsi(-1, 1, 11, 0, 32) # Magenta (secondary color)
hsi(-3, 1, 4, 0, 8) # Yellow (secondary color)
hsi(-1, 1, 13, 0, 16) # Cyan (secondary color)
#### DENOISING ##################
fft3dfilter(sigma=3.3,sigma2=2.2,sigma3=1.6,sigma4 =1.9, bt=2, bw=16, bh=16, ow=8, oh=8,plane=1, sharpen=0.0,interlaced=false,dehalo=0.0) # Chroma U
fft3dfilter(sigma=3.5,sigma2=2.2,sigma3=1.6,sigma4 =1.9, bt=2, bw=16, bh=16, ow=8, oh=8,plane=2, sharpen=0.0,interlaced=false,dehalo=0.0) # Chroma V
fft3dgpu(bt=2,sigma=3.3,sigma2=2.2,sigma3=1.6,sigm a4=1.9,bw=32,bh=32,ow=16,oh=16,sharpen=0,plane=0,m ode=1,precision=2,interlaced=false,oldfft=false) # Luma Only
GradFun2DBmod(str=[<"Grain Quality", 1.0, 10.0, 1.1>])
StackVertical(input, last) # for comparison purpose Before / after processing
weave()
QTGMC(preset=TestFunction(4))
SelectEven() # Add this line to keep original framerate, leave it out for smoother doubled framerate*** DIGITIZING VHS / ANALOG VIDEOS SINCE 2001**** GEAR: JVC HR-S7700MS, TOSHIBA V733EF AND MORE -
I still haven't had the time to try and figure this one out yet...I took a glance at it last night and it looked very confusing but I think it could be useful as you said. Can you give me an example of what a script starting out in avspmod might look like...with the histogram function you mentioned and all...
Just copy & paste your eariler script
A simple script might be
AVISource("video.avi")
Coloryuv(#some settings)
Histogram("levels")
Push f5. Change the coloryuv settings, push f5 again. etc....
Read the instuctions on the settings for each filter
e.g. for coloryuv
http://avisynth.org/mediawiki/ColorYUV
You 're going to kick yourself at how easy it is . I don't know people use avisynth without avspmod . It allows you to "see" what you're doing instead of working blindly and you get (almost) instant feedback to make adjustments -
I already told you what that does in this post:
https://forum.videohelp.com/threads/338999-Calibrating-luminance-levels-color-for-captu...=1#post2109859
It's the equivalent of reducing the color saturation by about 10 percent. It makes the colors less intense, more gray. +26 would have made all colors more intense. If you had opened a video and applied that line yourself you would have seen this easily. -
I should clarify one thing about ColorYUV(). When you use an option like gain_y=25 you aren't literally multiplying the luma value by 25. What you're really saying is y' = y + (y * 25 / 256). So gain_y=25 increases y by about 10 percent (25/256). If you specify a negative value, gain_y=-25, you are decreasing y by about 10 percent. It's the same for cont_y, gamma_y, and the U and V equivalents. off_y=25 is a literal addition of 25 to the luma value. off_u, and off_v are the same.
capture VHS with Virtualdub , color tweaks
By smartel in forum Capturing and VCRReplies: 10Last Post: 19th May 2011, 07:34 -
Question about color levels in capture
By BrainStorm69 in forum Capturing and VCRReplies: 5Last Post: 5th Apr 2010, 20:43 -
? On calibrating my TV monitor
By sdsumike619 in forum EditingReplies: 1Last Post: 4th Nov 2008, 00:29 -
OK, one more time: IRE levels from AVI capture to DVD authoring
By sanlyn in forum Video ConversionReplies: 3Last Post: 13th Jun 2008, 14:54 -
NTSC IRE levels and DV camcorder Pass-Through capture.
By edDV in forum Capturing and VCRReplies: 84Last Post: 1st Jun 2008, 16:58
