Hi everyone
I have a Panasonic s48 dvd player and would like to know if there is something I can do to make it play multi region discs?
Can anyone help please?
Thanks![]()
There are no hacks for this player:
https://www.videohelp.com/dvdhacks/panasonic-dvd-s48/11528 -
Amazon (US) list the player as multi-region:
http://www.amazon.com/dp/B004Q77150/?tag=packy-20
I haven't found a guide on how to hack it, but it might be possible.
You could also try the region hacks for other Panasonic DVD players - at your own risk.
It's likely that if the hacks aren't compatible they'll simply not work, but there's always a chance that they might break the player:
http://www.dvdhacks.co.uk/hacksearch/hacksearch.asp?player=PANASONIC -
A lot of brand-name DVD players in region 2 areas are region-free out of the box. Did you try playing a bonafide Region 1 DVD already?
For the nth time, with the possible exception of certain Intel processors, I don't have/ever owned anything whose name starts with "i".
ONNHT 1080P Multi Region Code.
By gibbo27172 in forum Newbie / General discussionsReplies: 3Last Post: 23rd Jan 2014, 09:40 -
LG HT304SU DVD Multi region unlock code required
By mumbojumbo999 in forum DVD & Blu-ray PlayersReplies: 7Last Post: 8th Mar 2013, 03:16 -
Multi-region code for LG DP771 - does anybody know one?
By fiddlejon in forum DVD & Blu-ray PlayersReplies: 5Last Post: 5th May 2012, 11:08 -
Sony DAV-DZ265K- multi-region code required.
By alllleg in forum DVD & Blu-ray PlayersReplies: 0Last Post: 26th Mar 2009, 06:12 -
Need code for pioneeer bdp lx70 code for multi region ...
By SHERWOODSelectrical in forum DVD & Blu-ray PlayersReplies: 2Last Post: 21st Nov 2008, 12:42
