I tried to load a avi into the subject tool and got this error message...
I made the avi file using the screen capture program CamStudio with the encoder x264vfw - H.264/MPEG-4 AVC codec.TMPGEnc Authoring Works 4 Could not open the video part of the .... only the audio part can be opened.
The encoder came with the Win7codecs package.
I have upgraded to the latest TMPGEnc Authoring Works 4. I thought that it would take 264 as input in the latest version??
Bob
When I resize the video using Vdub using the same codec to 720x540 (same aspect ratio but multiple of 4 resolution) it now will load into TMPGEnc. Is that a necessary requirement that videos should be in multiples of 4 resolution to import H.264 into TMPGEnc Authoring Works 4??
Hello - I don't have the same product as you, but I have something similar, Tmpgenc 4.0 Xpress.
This program can open a file of the dimensions above without issue. It opened the file through the directshow
source filter. I tried it with the CoreAVC and FFDshow decoder, both successful.
TMPEnc Authoring Works 4 Problem with input AC3 Audio (5.1 channels)!!!
By JackyWang in forum Authoring (DVD)Replies: 10Last Post: 22nd Jun 2011, 10:46 -
What is the different between TMPGEnc Authoring Works 4 & TMPGEnc 4.0 XPres
By c1steady in forum Newbie / General discussionsReplies: 0Last Post: 28th Apr 2010, 21:32 -
TMPGEnc Authoring Works 4 updated with WTV input support
By gyoshi in forum Latest Video NewsReplies: 0Last Post: 4th Mar 2010, 12:05 -
Tmpgenc authoring works
By hamilton accie in forum Authoring (DVD)Replies: 2Last Post: 29th Jul 2009, 08:32 -
TMPGEnc Authoring Works v.4.0.4.24 - Authoring
By niteghost in forum Authoring (DVD)Replies: 8Last Post: 21st Jul 2009, 21:15
