Is it now possible? As far as i was concerned it wasn't, unless subs were hardcoded as part of the picture, or if you used divx6 or later, having the .divx extension. Recently i got hold of a couple of avi's with subtitles included as streams. How's is that possible? At first i thought they could be divx with extension changed to avi somehow, but media information inside MPC-HC showed codec as XVID.
Any thoughts?
I've asked before here and on the Divx forums, never found a real answer why Divx dropped support for these
subs, but if you install the old Divx 685, you can play them by accessing the icon in the lower right when the video plays.
It will work in any player (as far as I know) using dshow.
Best way to remove subtitle stream?
By rmdeboer82 in forum DVD RippingReplies: 1Last Post: 7th Jul 2010, 05:15 -
PGCedit shows one subtitle stream only?
By kpic in forum SubtitleReplies: 2Last Post: 13th May 2010, 18:32 -
How do you separate an AVI file into a video stream and an audio stream?
By VidHunter in forum MacReplies: 2Last Post: 1st May 2008, 03:27 -
Remove subtitle stream from MP4
By Digiface in forum DVD RippingReplies: 1Last Post: 21st Jan 2008, 09:41 -
Remove subtitle stream from MKV
By NinjaPanda500 in forum Newbie / General discussionsReplies: 2Last Post: 21st Nov 2007, 14:59
