    Oct 2008
    So everytime i use FAVC when it gets to the point of using wavi.exe it gets to 99% and crashes and asks do i want to close or debug. an unhandled win32 exception occurred in wavi.exe (6280)
    if i hit close it just finishes the current video. but its getting annoying to constantly have to hit close after each one. i would like to know how i can fix this or disable getting the message so that the dvd can finish without me having to watch it go.
    I like to start Favc and let it go overnight while im sleeping and if i cant get 1 video done since the stupid thing closes it becomes a pain in the butt.
    Also i dont know if im missing 1% of something
    has anyone ever had this issue? im ussing favc on windows 7 x64 edition and i did the corflags change to make it 32bit
    corflags.exe favc.exe /32bit+
    maybe if i add that to the wavi.exe it will fix it?
    Oct 2005
    666th portal
    you might try switching to a program still supported. AVStoDVD might work for you.
  3. DECEASED
    Jun 2009
    Heaven
    wavi.exe
    Not sure if this will be helpful at all, but maybe your version of wavi.exe is the b0rked/outdated one
    Anyway, here is the fixed build by tebasuna51:
    Oct 2008
    thanks to both. for the wavi can i just simple place that file into the folder and replace the other?
