Hello,
This is a newbie question and I know it will be a simple one for you video geniuses on here
I am using DVDStyler and I have my main menu and several titles that I added separately to make chapters and they are all linked fine.
Which post command do I use so that after my Title/Chapter has played it will return to the main menu?
The options are:
Call Last Menu
Call vmgm Menu 1
Call Menu
Jump Title 1
Exit
I have tried several of them and opted for the Preview option but I guess the player isn't playing the video like a DVD player would because it is not returning to my main menu after a title has finished playing...And I really don't want to waste ANOTHER disc trying the real thing lol.
Also, I am using a Menu, not a vmMenu (I'm not really sure what the difference is, either).
Thanks!
If you used one of the Styler's default menu to create you DVD, than you do not need to play with commands. Styler will generate DVD with Root Menu which will have all the titles you put in plus "Play All" button. Play All will play each title consecutively and at the end will come to main (root) menu.
If you want to play each title individually, than click on any title window in the menu and that title will play, returning back to main menu at the end of that title.
To view what you will get, you can generate ISO file instead of burning disk, than extract VIDEO_TS folder files to your hard drive using WinZip or WinRar.
Than you can play them with any video player, Window Media Player will do.
If you want to test it on your player, you can burn them to a DVD Rewritable disk.
Quick Question
By TagFan in forum DVB / IPTVReplies: 3Last Post: 26th Sep 2011, 09:45 -
Title Playback Pre & Post Commands, back to menu, select next button
By louv68 in forum Authoring (DVD)Replies: 4Last Post: 19th Feb 2009, 19:24 -
Question about certain dos commands
By jimdagys in forum ComputerReplies: 35Last Post: 15th Oct 2008, 22:57 -
Edit VM Commands and UOP & Settings Question [DVDLabPro]
By urdivine in forum Authoring (DVD)Replies: 20Last Post: 23rd Sep 2007, 15:44 -
Dvd Author Ignoring jump chapter n in title pre commands (no errors)
By FallenAngel10 in forum Authoring (DVD)Replies: 0Last Post: 7th Jul 2007, 16:04
