I record AVCHD with sony DSC TX9
every site that i've been to says it records at 60 fps or 50 fps.
when i import the clip to my computer it says 25 fps
what am i doing wrong?
I import my clips to Sony Vegas, Cyberlink, After effects and they all say 25 fps...
how do i fix that ?
Thanks in advance
25FPS is correct
sony website says interlaced
1080i25 (or sometimes called 1080i50) is 50 fields per second or 25 frames per second ie. 25FPS
http://store.sony.com/webapp/wcs/stores/servlet/ProductDisplay?catalogId=10551&storeId...specifications
Video Mode : AVCHD 1920x1080 (59.94i, Interlace)(Approx.17Mbps) / 1440x1080 (59.94i, Interlace)(Approx.9Mbps) MP4 1440x1080 (29.97fps, Progressive)(Approx.12Mbps) / 1280x720 (29.97fps, Progressive)(Approx.6Mbps)/VGA (640x480)(29.97fps, Progressive)(Approx.3Mbps)
Thank you so much for answering..
so i guess this is wrong?
http://reviews.cnet.com/digital-cameras/sony-cyber-shot-dsc/4505-6501_7-34147094.html#reviewPage1
high-resolution 3.5-inch touch-screen LCD, and 1080i movie capture at 60 frames per second--all in a body that's just 0.7 inch thick -
if you look down lower in the specs they list it as.
4,000x3,000 pixels/1,920x1,080 (59.94, interlaced; 17Mbps), 1,280x720 (29.97fps, progressive; 6Mbps)
it's 59.94 fields/second = 29.97 frames/second
AVCHD on hard drive: creating new AVCHD folder structure
By Phil_W in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 1st May 2011, 14:46 -
software to batch convert m2ts format avchd to mts avchd?
By masterpug in forum Video ConversionReplies: 0Last Post: 14th Aug 2010, 01:06 -
Wrong frame rate (30 fps) for DvdMaestro. Any solutions?
By conax in forum Authoring (DVD)Replies: 3Last Post: 30th Jun 2009, 17:36 -
How to convert a video of 120 Fps to... well 23.9fps or 25 fps or 30 fps
By Chuba753 in forum Newbie / General discussionsReplies: 7Last Post: 6th Jun 2008, 19:17 -
Playing AVCHD on plasma using WMP=wrong AR
By EliG in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 29th Oct 2007, 11:54
