  1. Hello, do you know why Ffmpeg can't convert this video ? Is there something wrong in the conversion command?
    Thank you!
    Started on 2011-09-15 19:33:01 - 2011 Sep 15
    Checking File ....
    File : /home/livefeti/public_html/files/conversion_queue/1316107943961c5.avi
    File Exists : Yes
    Preparing file...
    format : avi
    duration : 321.12
    bitrate : 311
    video_width : 320
    video_height : 240
    video_wh_ratio : 1.33333333333
    video_codec : msmpeg4v2
    video_rate : 15.0006228201
    video_bitrate : 306
    video_color : N/A
    audio_codec : N/A
    audio_bitrate : N/A
    audio_rate : N/A
    audio_channels : N/A
    path : /home/livefeti/public_html/files/conversion_queue/1316107943961c5.avi
    Converting Video
    Conversion Command : /usr/local/bin/ffmpeg -i /home/livefeti/public_html/files/conversion_queue/1316107943961c5.avi -f flv -vcodec libx264 -vpre medium -r 30 -b 640000 -s 320x240 -aspect 1.33333333333 -vf 'pad=0:0:0:0:black' -acodec libfaac -ab 128000 -ar N/A -map_meta_data /home/livefeti/public_html/files/videos/1316107943961c5.flv:/home/livefeti/public_html/files/conversion_queue/1316107943961c5.avi /home/livefeti/public_html/files/videos/1316107943961c5.flv 2> /home/livefeti/public_html/files/temp/1316107982906c4.tmp
    Conversion Details
    FFmpeg version SVN-r26402, Copyright (c) 2000-2011 the FFmpeg developers
    built on Jul 27 2011 09:35:30 with gcc 4.1.2 20080704 (Red Hat 4.1.2-50)
    configuration: --prefix=/usr/local/cpffmpeg --enable-shared --enable-nonfree --enable-gpl --enable-pthreads --enable-libopencore-amrnb --enable-decoder=liba52 --enable-libopencore-amrwb --enable-libfaac --enable-libmp3lame --enable-libtheora --enable-libvorbis --enable-libx264 --enable-libxvid --extra-cflags=-I/usr/local/cpffmpeg/include/ --extra-ldflags=-L/usr/local/cpffmpeg/lib --enable-version3
    libavutil 50.36. 0 / 50.36. 0
    libavcore 0.16. 1 / 0.16. 1
    libavcodec 52.108. 0 / 52.108. 0
    libavformat 52.93. 0 / 52.93. 0
    libavdevice 52. 2. 3 / 52. 2. 3
    libavfilter 1.74. 0 / 1.74. 0
    libswscale 0.12. 0 / 0.12. 0
    Input #0, avi, from '/home/livefeti/public_html/files/conversion_queue/1316107943961c5.avi':
    Metadata:
    encoder : Lavf53.2.0
    Duration: 00:05:21.12, start: 0.000000, bitrate: 319 kb/s
    Stream #0.0: Video: msmpeg4v2, yuv420p, 320x240, 25 tbr, 25 tbn, 25 tbc
    Metadata:
    title : aerstw01.avi Video #1
    Expected number for ar but found: N/A
    xcpt: mmfile: unable to open file /home/livefeti/public_html/files/videos/1316107943961c5.flv
    Failed to stat file /home/livefeti/public_html/files/videos/1316107943961c5.flv!
    Unknown file details - Unable to get output video details using FFMPEG
    Time Took : 0.3606 seconds
    conversion_status : failed
  2. Member bat999's Avatar
    Feb 2008
    It's a weird command.
  3. yes ffmpeg is in a website ...
    Sep 2007
    Europe
    The log you posted is clear about it!
    Your FFmpeg command line shows -ar N/A. If you convert only video, remove it or set it to something like -ar 48000.
