I made a screencast of my desktop. It's 1024x768, 15fps, Theora .ogv at quality 100 created using gtk-recordMyDesktop on Ubuntu.
That file's quality is flawless. Now, when I try to render it to something an iPad would play, it becomes rather blurry.
I'm rendering to Kdevlive's default preset for iPhone, with the resolution changed to 1024x768.
I tried tweaking the options (resolution and bitrate), but even 10,000k was blurry.
What could be the reason? Does it have anything to do with Progressive/Interlaced? or something else I'm not aware of?
Here are my rendering settings in Kdenlive:
Code:s=1024x768 aspect=%dar progressive=1 acodec=aac ab=128k vcodec=libx264 b=1000k flags=+loop cmp=+chroma partitions=+parti8x8+parti4x4+partp8x8+partb8x8 me_method=umh subq=7 me_range=16 g=250 keyint_min=25 sc_threshold=40 i_qfactor=0.71 qcomp=0.6 qmin=10 qmax=51 qdiff=4 directpred=1 trellis=1 coder=0 bf=0 refs=3 flags2=-wpred-dct8x8 level=30 maxrate=10000k bufsize=10000k wpredp=0
Results 1 to 10 of 10
h.264 uses 4:2:0 chroma subsampling. Small colored objects and sharp colored edges will always get blurred. Some examples:
https://forum.videohelp.com/threads/294144-Viewing-tests-and-sample-files?p=1792760&vie...=1#post1792760
https://forum.videohelp.com/threads/308120-Quality-loss-from-D-V-AVI-to-other-formats?p...=1#post1897056Last edited by jagabo; 15th Sep 2011 at 10:53.
I added links to some examples to my previous post. Are you seeing something worse than that?
It's exactly what I'm seeing, so that seems to be the source of the problem. Is there a way of using 4:4:4: with a format that'll be readable on an iPad? (ideally H.264)
EDIT: I noticed this section in the Kdenlive settings I posted above:
Wouldn't that have something to do with chroma subsampling?cmp=+chroma partitions=+parti8x8+parti4x4+partp8x8+partb8x8
EDIT2: Wikipedia says it's possible with profile High 4:4:4 Predictive Profile (Hi444PP)Last edited by poing; 29th Sep 2011 at 10:29. Reason: link
ipad doesn't support 4:4:4 profile . Heck most h.264 software decoders don't even support it (yet)
^yeah it's not something that can be improved by a firmware fix. It's a hardware decoding chip issue. Maybe ipad version 6 or something in 2024. But by then we will have quadHD resolution on ipad
Good (preferably free) screencast program...
By gutterboy in forum Newbie / General discussionsReplies: 12Last Post: 4th Sep 2011, 19:43 -
Compressing screencast videos
By pointzero in forum Newbie / General discussionsReplies: 1Last Post: 9th May 2011, 15:20 -
What Screencast Codec?
By BlaenkDenum in forum Video ConversionReplies: 3Last Post: 5th Apr 2008, 21:09 -
How can I autoplay a .flv video on Screencast?
By add2it in forum Video Streaming DownloadingReplies: 3Last Post: 7th Mar 2008, 13:19
