Can someone help me identify an appropriate software application to help reduce camera shake on videos that I took of my niece’s wedding (so a post-production reduction as it were).
I want a reliable piece of software that is easy to install and use but inexpensive (if there is a good freeware piece of software that would be perfect).
I am fairly new to this forum (and making video’s) as this is only my second post, so please be gentle with me if the answer is obvious. I am using DVD creation software: ‘DVDFlick’ (not sure, if this is relevant) to create my DVDs
After Effects has a pretty good one built in, but it ain't cheap. DeShaker can do a reasonable job, especially given the price. However it also depends on how bad the movement is, if your footage is interlaced or progressive, and other factors. If the movement is too extreme it may not be salvageable in a way that makes it useful. Can you post a sample ?
Read my blog here.
Prodad Mercalli V2. This really works but, it will cost you about $119, stand alone version. It makes shaky video tripod straight.! If you do lots of video editing, this is a must. You can download a trial version to see how good and easily it works. It is also included as a plugin in VideoStudio Pro X4 Ultimate.
Vegas Pro has stabilization built in, and a free 30 day trial. Don't know about the "Studio" line.
Like mentioned above, it all depends how bad it is. If you can manually correct the worst parts, you'll get a better result. In Vegas, the pan/crop tool can do this with keyframes, and set all keyframes to "smooth". -
Vegas Movie Studio will stabalize as well. For the record I think all deshake methods "zoom" in. The image has to be cropped because the image is moved in opposition to the unwanted motion to create a "stable" image. In order to move the image around, the image has to move outside the boarder of the original video frame. Programs that don't crop are likely doing some kind of pixel stretching at the boarders.
Hi,
Where do you see it anywhere online for even close to $119?
This seems to be a great product and essential as I'm an editor and cameraman.
Thanks. -
I want to thank everyone for replying to my post. I am going to try a few of the ideas suggested, and I will let everyone know how I got on.
All Thanks
Dan T.
How to Remove Camera Shake from iPhone 4S Videos (Batch Deshaker Script)
By preshing in forum EditingReplies: 1Last Post: 17th Apr 2012, 22:35 -
CUDA - Accelerated encoding for post production
By Wile_E in forum Newbie / General discussionsReplies: 2Last Post: 6th Jan 2011, 06:58 -
Extending VGA Signals For Video Post Production House
By avsubvert in forum DVB / IPTVReplies: 0Last Post: 27th Nov 2009, 06:47 -
Field camera for broadcast/production?
By Mylo in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 13Last Post: 24th Oct 2009, 15:43 -
High Def Post Production
By mark25s in forum MacReplies: 5Last Post: 28th Feb 2008, 20:50
