Hi all.
Is anything supposed to appear onscreen if an nVidia GTX260 graphics card is connected to the motherboard without connecting the two 6-pin PCI-Express connectors from the PSU to the graphics card?
Four unrelated questions - the following manual states 'The front panel audio header supports Intel High Definition audio (HD) and AC'97 audio' on page 30.
http://download.gigabyte.eu/FileList/Manual/mb_manual_ga-890gpa-ud3h_v2.1_e.pdf
Which option provides the better quality audio?
Does it make any difference if the video isn't HD?
Does the Intel High Definition provide Dolby surround and 2/4/5.1/7.1-Channel Audio also?
Does listening via headphones affect the answers to any of the above questions?
Any advice would be very appreciated.
Thanks.
that card won't work at all without the power plugs in. but it may burn out the pci x16 slot by trying to draw too much power.
the m.b. header pins are just for connecting additional headphone mic type jacks to the front of the case. the h.d. output is already going to the back ports.--
Thanks for your reply aedipuss.
The front headphone jack is what I use for my audio. Is sound better for all purposes on AC'97 or Intel High Definition audio (HD)?
Thanks. -
the hd is newer and has more features. but it depends on what your computer case has for a front panel (hd or ac97 type) which you use. they are hooked up differently.
Hi aedipuss. It has both an AC'97 and an HD. At the moment I have the AC'97 plug connected to the motherboard. If I want HD, I have to remove that and plug in the HD one. Thanks for your help.
Need another graphics card already!
By A Traveller in forum ComputerReplies: 15Last Post: 26th Sep 2011, 16:07 -
Very Weird issue with Capture Card and Graphics Card? Please help
By Ps3riiper in forum ComputerReplies: 9Last Post: 11th May 2011, 15:51 -
Audio From Graphics Card?
By therock003 in forum AudioReplies: 7Last Post: 11th Jul 2008, 08:15 -
need a new graphics card..
By SE14man in forum Newbie / General discussionsReplies: 11Last Post: 28th Dec 2007, 01:50 -
What sort of Graphics Card/Capture Card to get
By Dr_trout in forum Capturing and VCRReplies: 4Last Post: 24th Jul 2007, 15:19
