1. pixelation in a video clip
2. choppy video - the video freezes momentarily and then plays smoothly for a time and then such behaviour repeats as this is in the transmissionsignal i receive on mt set top box
Is their a progra, or praograms that i can run the videos through or a set of filters - perhaps?
I suspect what your describing is the result of a weak signal -- so some of the MPEG packets were dropped, corrupting the picture. No, you can't restore the original video. Sometimes you can do things like lock still frames during segments where the picture gets corrupt, maybe use motion vectors to restore some corrupt panning shots, copy bits from good frames over the corrupt portions of bad frames. But it will be a lot of work and the results won't be perfect.
If you post a short sample I'm sure someone will take a look at it.
How do I identify faults in MPEG files? Authoring programs crash...
By semmel in forum Authoring (DVD)Replies: 7Last Post: 1st Oct 2008, 23:28 -
Tool to detect avi/divx's for faults
By tfamok in forum Newbie / General discussionsReplies: 1Last Post: 15th Jul 2008, 14:08 -
Error before burning dvd!please get this rectified
By g_pentium in forum Authoring (DVD)Replies: 9Last Post: 21st Aug 2007, 21:57
