I'm currently running a Intel Core 2 Quad Q6600 Kentsfield 2.4GHz which is a few years old now. I'd like to buy a new $500 or so complete system for video encoding, perhaps from Newegg, Tigerdirect, etc. Any pre-built systems that you can recommend that will perform better than my current system? From what I recall, Intel consistently performs better with video encoding so that's a starting point at least.....
 I think you need to slow down and examine your assumptions.
 What are you trying to accomplish?Recommends: Kiva.org - Loans that change lives.
 http://www.kiva.org/about
	No assumptions here. One of the office PC's went down and I need to buy a new system. I'll pass my current video editing system along to that person. Whatever I buy today for around the same price that I bought a few years ago, is going to be better just by the nature of how the CPUs continue to improve. I want to know what pre-built system from newegg or tigerdirect, for my budget I should get for best performance in video encoding.
	The "prebuilts" often have in inferior components and/or are full of crapware. Better to build your own or work with a local custom PC shop. Recommends: Kiva.org - Loans that change lives.
	I know about all the junk software.. The hard drive can always be wiped clean and start with a clean OS. I'm more interested in the hardware. With encoding, the CPU is the most important component, so I was looking for a pre built budget system with a good CPU for encoding. I'm not looking for top of the line obviously.. The Intel I5 looks pretty nice from what I've read so far..
	Ok, I've decided to go the build my own route. Been reading on this page:
 http://www.videoguys.com/Guide/E/Videoguys+System+Recommendations+for+Video+Editing/0x...ce243a6c6.aspx
 Do you like their recommendations?
 Thinking of going with this CPU:
 http://www.newegg.com/Product/Product.aspx?Item=N82E16819115074
 But not sure which motherboard to purchase with it....
	i might go for the newer Core i5-2405S with hd3000 graphics or an i5 "k" model with unlocked multiplier for overclocking.
 motherboard depends a lot on whether you want to use the cpu's onboard graphic or an add-in video card.--
  Problem while encoding AVCHD video with Sony VegasBy RiDDleR2 in forum EditingReplies: 6Last Post: 29th Jul 2011, 11:41
  [Help Request] Sony Vegas 10 Pro, AVC/H.264 EncodingBy lindenkron in forum Newbie / General discussionsReplies: 91Last Post: 8th Jul 2011, 04:14
  sony vegas 10 to feature gpu powered avc encodingBy deadrats in forum Video ConversionReplies: 17Last Post: 12th Oct 2010, 00:02
  Importing from SONY HDR-SR1 to SONY VEGAS 8 MPEG Video resolutionBy UltimateEnd in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 19th Oct 2009, 12:00
  Encoding to H.264 from Sony Vegas 8By BlaenkDenum in forum EditingReplies: 5Last Post: 16th Jul 2008, 02:41
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
