Results 1 to 17 of 17
  1. Hi all,
    I have ordered a Sony Handycam HDR-CX115E, my 1st HD Camcorder. Asking if you use the highest quality settings on the camera how many hours will I get of filming using a 8gig or a 32gig SD card?
    Also can anyone recommend a good solid card please? Not bothered about the price.
    Thank you
  2. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    You can buy an SD card but I doubt it will fit in a Sony.
  3. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    The card type recommended (usually class 6 up) and record times should all be spelled out in the manual.
    http://www.kiva.org/about
  4. Originally Posted by hech54 View Post
    Ok, thanks, what type of card do I need? As the camcorder is still on order!
    Thank you
  5. Originally Posted by edDV View Post
    Sorry, what is a class 6? New to this HD thingy?
    Thank you
  6. Member edDV's Avatar
    Mar 2004
    If your camcorder did use SD cards it would be this
    http://www.buy.com/retail/product.asp?sku=218192954&sellerid=9533078
    But as hech24 said, it doesn't. Your camcorder requires Sony Memory Stick Pro Duo flash ram cards. The manual will tell you which one. You can download the manual.
  7. Member turk690's Avatar
    Jul 2003
    ON, Canada
    Sony has quietly made its latest generation camcorders, like this HDR-CX115, accept SD cards alongside memory stick. Good for all of us.
    For the nth time, with the possible exception of certain Intel processors, I don't have/ever owned anything whose name starts with "i".
  8. Originally Posted by turk690 View Post
    Yes, and because of this I may actually buy a Sony camcorder. I always despised their propritary memory.
    Nov 2000
    Canada
    Handycams I don't know. DSLRs usually use Class 10. My ereader (Kobo) uses Class 4. Check your manual to be sure you have the right class card before buying anything...
  10. Josel, the higher the class of the card the less dropped frames you will have. The manual should state what the lowest class card the camcorder will accept. Since you stated that price was not a factor, I would go with a 32gb class 10 card. I bought one from Pny for my GoPro and have been very happy with it.
  11. Everyone stop telling the OP what card to buy unless you know what his camera needs. For example, my Canon HF100 will not recognize class 10 cards because the class didn't exist when the camera was made. Let the OP read the manual and buy the manufacture specified card.
  12. Originally Posted by magillagorilla View Post
    That's false. You need to upgrade your firmware to 1.0.3.0. Your camera came out 4/2008, class 10 cards were first introduced 5/2009. I have a nikon d40x from 3/2007 that accepts class 10 cards. So to say that a piece of equipment will not accept class 10 cards because the class didn't exist is just not right.
  13. Member papakilo's Avatar
    Feb 2004
    Walhalla S.C.
    From specifications on the Sony site
    Recording Media
    Memory Stick PRO Duo Mark II, Memory Stick PRO-HG Duo, SD/SDHC/SDXC Memory Card (Class 4 or higher)
  14. Member edDV's Avatar
    Mar 2004
    Recording Media
    No reason to go below Class 6 these days. No more expensive. Less likely to drop frames.
  15. @papakilo, good work. Much better than blind recommendations.
    @mrswala, you are correct. My statement is a little off. Were my camera not firmware upgradeable class 10 cards would not work. I am assuming that they do not work because the class 10 specification did not exist, at the time of the firmware codeing, and therefore could not be written in to firmware. However, not all hardware has updatable firmware. So if a specification does not exist at the time in which a product is produced it would be foolish to assume that the product is forward compatible with the specification.
    I wasn't trying to harsh on anyone. I just didn't want the OP to run out and buy a card that doesn't work.
  16. Thank you all for your advice.
  17. Member techiejustin's Avatar
    Oct 2006
    PA, United States
    http://www.sony.co.uk/product/cam-high-definition-on-memory-stick/hdr-cx115e#pageType=TechnicalSpecs
    According to the above link not only can the CX115 use the Sony Memory Stocks, but it can use the standard SDHC memory cards as well.
    Recording Media
    Just a heads up, newer Sony camcorders are able to use standard SDHC cards - not the Sony Proprietary Memory Stock/Pro.
    EDIT: Did not see papakilo's post.
    Sorry about that.
