Hi,
I have been capturing HDV ( 1440 x 1080 x 25fr interlaced ) with the latest Vegas HD Movie studio.
I then encode to PAL DVD widescreen specs.
My problem is that the bitrate calculator i have been using for years for AVI to MPG2, is no longer accurate
for these larger and more complex HDV files it seems and I end up waiting 2 - 3 hours just to find out my
MPG2 file is a few hundred mpg too big for DVD.
Example ... i just encoded a 68 min HDV at 7900kbs + 192 audio and ended up with a 4.5g mpg2, however
my current bitrate calcultor said i should be OK with approx 8500kbs
I can't find a suitable calculator for HDV to DVD
Any tips ?
Why is an intelligent man's vote, worth the same as an idiot's vote in a democratic election system.
Have you checked the average bitrate in the encoded mpg with for example Bitrate viewer?
What does fitcd or https://www.videohelp.com/calc calculate with same settings? They include the dvd/mpg overhead data also. -
Thanks for the info. https://www.videohelp.com/calc doesn't predict an accurate size mpg2 DVD file in regards to HDV to DVD widescreen specs, as I've tried this previously. I will however do some analysis on my DVD mpg2 files to see if Movie studio isn't bumping up the bitrate without my knowledge.
cheers
ScottWhy is an intelligent man's vote, worth the same as an idiot's vote in a democratic election system. -
The source of the video makes no difference to the bitrate calculations. Only the properties of the output video matter. If your getting files that aren't the right size your encoder is screwing up. Or the calculator is wrong.
Simple math:
7900+192=8092 kbps
68 min * 60 sec/min = 4080 sec
8092 * 4080 = 33,015,360 kb
33015360 / 1024 kb/Mb / 1024 Mb/Gb / 8 bits/Byte = 3.94 GB
This says that "IF" your encoder is encoding at an average bitrate that you set it at (7900v+192a), it will fit. No 2 ways about it. Can't be "wrong calculator".
The problem is with your encoder. It either isn't set to that correct bitrate, or it's set to some VBR/CQ setting that is letting it vary enough that the average is NO LONGER what your target average is supposed to be, or you have a crappy encoder.
What are you using, Vegas HD Movie Studio? What are the settings?
advice on specs needed for new pc
By angryassdrummer in forum ComputerReplies: 4Last Post: 21st Jun 2011, 02:31 -
MPEG Question regarding specs (Bitrate, Ratio, Resolution)
By hcowan in forum Newbie / General discussionsReplies: 5Last Post: 31st Jan 2011, 16:26 -
Help needed: Lossless (fast) DVD -> mpg2 -> DVD, How to?
By dvddummy2 in forum Video ConversionReplies: 2Last Post: 30th Aug 2010, 11:21 -
HDV & DV framerate vs bitrate
By turk690 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 8th Feb 2008, 12:49 -
Why was 48khz needed for DVD specs?
By yoda313 in forum AudioReplies: 3Last Post: 7th Jul 2007, 16:57
