I'm an actor and I have a dvd that I need to include on my reel. I am using cinelerra CV 2.1.5. The video portion plays well in Cinelerra but there is no sound. The dvd has the following codec info (taken from vlc):
stream 0:
type subtitle
codec: DVD subtitles (spu)
stream 1
type:video
codec: MPEG-1/2 video (mpgv)
resolution 720x480
framerate 59.940059
stream2
type:video
resolution 720x480
framerate 59.940059
stream 3
type audio
codec DVD LPCM Audio (lpcm)
language English
channels: stereo
Sample rate 48000 Hz
bits per sample: 16
It's the audio that is giving me a problem. i need to convert it to something I can use in cinelerra
I am using linux mint 11
thanks in advance.
It imports fine and you can view it in the viewer. But there is no sound. My other DVD's use a52 for the audio codec. for some reason this uses pcm for the audio codec and it is not supported. I need to convert it somehow to a supported codec
How to convert FLV videos and resize them to convert them to AVI
By zikegi in forum Video ConversionReplies: 2Last Post: 17th Sep 2011, 23:06 -
Convert AVI (miniDV) to MKV/MP4, large files only convert partially
By Video Eddie in forum Video ConversionReplies: 0Last Post: 3rd Jan 2011, 05:44 -
how to convert dvd with dts audio to a dvd playable on a dvd player
By flannob in forum Newbie / General discussionsReplies: 5Last Post: 19th Sep 2010, 06:46 -
To convert or not to convert a pal dvd
By nls8520 in forum Video ConversionReplies: 1Last Post: 22nd Jun 2010, 01:35 -
Convert PAL 16x9 DVD to NTSC DVD w/ Procoder - Less Image-More Borders Why?
By tubularusa in forum DVD RippingReplies: 15Last Post: 5th Aug 2007, 01:26
