I asked this question a couple of weeks ago, but got no responses (hopefully because it's not too dumb a question!)
May I try again? If I have, say, a 1 GB AVI xvid video and want to do some light filtering on it, I know it will need to be re-encoded.
But since I'm putting it on a DVD disk, it won't need to be compressed any more than it was, and could actually be larger.
h.264 seems to be the codec of choice now for compressing, but since I really don't need to compress it any more than it was,
is h.264 any better in this case than the other popular codecs like xvid, divx, or mpeg2?
If it needs to play on a DVD player as a DVD, the only choices are AC3, mp2 or PCM (uncompressed). If it needs to play on a DVD player as a file, most will support divx/xvid in addition to the above.
While a better codec, h.264 needs player support. How will you play this file?Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
If you have a Divx/DVD player you can reencode with Divx or Xvid. If you want to make a standard movie DVD that will play in all DVD players you need to convert to MPEG 2. If your editor doesn't output MPEG 2 video (VirtualDub, for example) use a lossless codec like HuffYUV, then use your MPEG 2 encoder to encode that.
Thanks for the replies. I have until now converted to mpeg2 and made a regular DVD disk out of it. I have an older model DVD player. Now I'm considering moving to the 20th century and getting a BluRay player. So maybe with the right player I could use mkv or make an AVCDH disk. I don't want to spend the money for a BluRay burner right now. I probably wasn't clear in my intent. So in this instance, would the h.264 format (mkv or AVCHD) be any better than what I'm doing now? (Does that make it clear as mud?)
Next comes research for the right Blu-Ray player. Some have dropped divx/xvid support but most all support DVD MPeg2/AC3.
SD h.264 may prove tricky especially in an mkv wrapper.
I haven't tested many Blu-Ray players for SD. If you use h.264, the container will be the issue. HD safe path is a m2ts container.Recommends: Kiva.org - Loans that change lives.
Right. The research continues. But as for the codec issue, is the h.264 any better for what I'm trying to do than the mpeg2? I know it takes a lot more horsepower and apparently time, too, so I'm wondering if it's worth it.
How to maintain quality with avidemux? (which video codec?)
By tlee in forum Video ConversionReplies: 7Last Post: 7th Nov 2010, 07:39 -
what is the video codec which compress and keep the most quality part ?
By Michael REMY in forum Video ConversionReplies: 3Last Post: 28th Aug 2010, 09:03 -
Highest quality codec
By chizzle in forum Blu-ray RippingReplies: 6Last Post: 11th Feb 2009, 15:57 -
Want to produce videos that are high quality. i need h264 codec.
By snafubaby in forum Newbie / General discussionsReplies: 3Last Post: 19th Dec 2008, 10:24 -
codec quality ranking
By akrako1 in forum Newbie / General discussionsReplies: 11Last Post: 10th Nov 2007, 22:24
