Hello everyone.
So, I've been trying to find a 10-bit option on meGui, i also uploaded the x264.exe file but i can't encode 10-bit.
Can anyone help me with this please?
According to some...you just have to replace x264 with the 10 bit x264 downloaded from http://www.x264.nl/x264_main.php
But after I replace the original x264 with the 10 bit x264 megui will give error saying it need updating then will replace 10 bit x264 with it's own standard x264. -
Running 10-bit as we speak. Replace x264.exe or x264_64.exe with the 10-bit version AFTER you run update. As long as you are encoding 2-pass or CRF nothing changes. If doing QP (which you shouldn't.....) add 12 to your QP number or else you will have 4x bigger files.
if all else fails read the manual
Megui encoding stops
By sanosuke in forum Video ConversionReplies: 1Last Post: 20th Dec 2012, 21:36 -
megui 64 bit mode avs4x264mod.exe
By killerteengohan in forum EditingReplies: 0Last Post: 10th Mar 2012, 22:10 -
Is there any way to encoding VFR using Megui?
By The Scenes in forum Newbie / General discussionsReplies: 13Last Post: 25th Apr 2011, 08:36 -
Can Megui 3.5.3.23_x64 be used with Avisnyth 2.5 32 Bit?
By Laserbelly in forum Newbie / General discussionsReplies: 0Last Post: 25th Oct 2010, 00:42 -
MeGUI encoding error
By kadyn67 in forum Blu-ray RippingReplies: 9Last Post: 18th Jun 2010, 00:26
