Results 1 to 23 of 23
  1. Member koberulz's Avatar
    Oct 2006
    Australia
    As per topic title. No audio track even drags in when I try to drop it into a sequence.
    MediaInfo:
    General:
    Format : MPEG-TS
    File size : 4.43 GiB
    Duration : 44mn 30s
    Overall bit rate : 14.2 Mbps
    Maximum Overall bit rate : 18.0 Mbps
    Video:
    Menu ID : 1 (0x1)
    Format : AVC
    Format profile : Main@L4.0
    Format settings, CABAC : Yes
    Format settings, ReFrames : 4 frames
    Format settings, GOP : M=1, N=64
    Codec ID : 27
    Duration : 44mn 30s
    Bit rate mode : Variable
    Bit rate : 13.1 Mbps
    Maximum bit rate : 20.0 Mbps
    Width : 1 920 pixels
    Height : 1 080 pixels
    Display aspect ratio : 16:9
    Frame rate : 25.000 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Interlaced
    Scan order : Top Field First
    Bits/(Pixel*Frame) : 0.254
    Stream size : 4.09 GiB (92%)
    Color primaries : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
    Transfer characteristics : BT.709-5, BT.1361
    Matrix coefficients : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177
    Audio:
    Menu ID : 1 (0x1)
    Format : AC-3
    Format/Info : Audio Coding 3
    Codec ID : 129
    Duration : 44mn 30s
    Bit rate mode : Constant
    Bit rate : 384 Kbps
    Channel(s) : 2 channels
    Sampling rate : 48.0 KHz
    Bit depth : 16 bits
    Compression mode : Lossy
    Delay relative to video : -120ms
    Stream size : 122 MiB (3%)
    VLC says it's in surround sound, though.
  2. You can try re-wrapping with tsmuxer , tsremux or ffmbc then import it
    Or maybe demux the audio , convert to wave and import it separately
    Or maybe stream copy the video, convert the audio into a new container (e.g. avidemux)
    Or maybe use VLC to convert it to some digital intermediate
  3. Member koberulz's Avatar
    Oct 2006
    Australia
    What would I use to do that?
  4. Originally Posted by koberulz View Post
    maybe with tsmuxer or eac3to or ffmpeg
    you can convert with eac3to, audacity, foobar2k, ffmpeg , etc...
  5. Member koberulz's Avatar
    Oct 2006
    Australia
    tsMuxer wouldn't import the audio, eac3to keeps telling me I need to select a source file/folder and a destination folder, even though I already have.
  6. if you are using a gui for eac3to, you have to setup the paths otherwise it won't work
    if you use commandline, it's
    eac3to input.m2ts -demux
    since vlc can play it , very likely ffmpeg can convert it or demux it or even re-wrap it . It's probably an non standard transport stream, that's why PP can't "see" the audio
    e.g for stream copy audio
    ffmpeg -i input.m2ts -vn -acodec copy output.ac3
    ffmbc works better for transport streams, if you re-wrap it, very likely premiere will "see" it
    ffmbc -i input.m2ts -vcodec copy -acodec copy -f mpegts output.m2ts
  7. Member koberulz's Avatar
    Oct 2006
    Australia
    I was using a GUI, and linked it to eac3to. It just insisted I needed to set up sources and destinations even though I already had.
    Tried using gui4ffmpeg, only outputting audio, and it threw out something about a CRC mismatch, an incomplete frame, and an invalid frame size, then crashed.
  8. maybe the gui is using old/outdated ffmpeg build ? or maybe you have errors in the stream ? ffmbc definitely works better with transport streams than ffmpeg
    if vlc can play it, it should be able to convert it
    maybe try avidemux nightly build to save the audio as wav
    http://avidemux.org/nightly/win32/
    where is this from ? sat recording ?
    do you have a small sample you can upload ?
  9. Member koberulz's Avatar
    Oct 2006
    Australia
    I downloaded ffmbc...no file extensions on 90% of it and I have no idea how to use it.
  10. It's a command line app; you can download a precompiled binary here
    https://www.videohelp.com/download/FFmbc-0.5-win32.7z
    Put the exe in the same directory as the video , open a command prompt and type in the commands, or copy & paste (change finename to match yours)
    Did you try the nightly build of avidemux ?
    You can also try DGAVCIndex to demux the audio
  11. Member koberulz's Avatar
    Oct 2006
    Australia
    'error, non monotone timestamps 334800 >= 10800'
  12. What is the source?
    Did you try the other suggestions ?
    If DGAVCIndex doesn't detect the audio automatically, manually set the PID or use the one that VLC identifies as the PID . You're only using it to demux the audio
    For example, in mediainfo:
    Stream=> Set PID's => I think you would enter "1100" (not sure)
  13. It's probably easiest to use VLC since it plays fine in VLC
    media => convert/save => add video => convert/save=> then setup a new profile (you might want to convert to wave, or only demux audio for example)
  14. Member koberulz's Avatar
    Oct 2006
    Australia
    What is the source?
    I captured it from this using this (optical audio cable, RGB video cables).
    I don't even know what you're talking about half the time. I know very little about this stuff.
    Opened with DGAVCIndex, demuxed. Imported the resulting ac3 file into Premiere, everything looked good...but it's in stereo. It starts in sync perfectly, for about ten seconds, and then cuts to a later point, and at about 11 minutes in it just starts repeating the same half-second over and over until the end of the video.
  15. Member koberulz's Avatar
    Oct 2006
    Australia
    Tried using VLC to convert to MP3, but all it ended up with was a .ps file, which doesn't even show up in Premiere's "Import" dialog.
  16. If this is 6-channel according to vlc, mp3 isn't supported (only stereo)
    I would copy the audio, and if it's a funny extension, rename extension to ac3
    (just make a conversion preset/profile in VLC, I think it's the last button)
  17. Member koberulz's Avatar
    Oct 2006
    Australia
    What settings should I use for the preset/profile?
  18. Member koberulz's Avatar
    Oct 2006
    Australia
    Bump?
  19. I don't know , I don't have a sample
    Try "keep original audio track" and uncheckmark video
    Or maybe try copying the video and audio into a new container
    If you search, a lot of people have problems with HDPVR recordings (at least recent versions)
  20. Member koberulz's Avatar
    Oct 2006
    Australia
    Alright, had a look around and used tsSniper. It wouldn't let me output an elementary stream or m2ts file, though (the option is there, but greyed out), and Premiere wouldn't let me import a .ts file, so I demuxed with tsMuxer. Success...sort of. The audio imports fine, but is out of sync with the original m2ts file. The tsMuxer-produced .264 file is completely useless, flashing green every now and then alternating with random pictures from the footage that occur nowhere near each other. Further, the audio is in stereo in Premiere, even though VLC reports it as being in surround sound.
  21. Maybe VLC is incorrect ? Do you hear real 6 ch when playing it ?
    You might get better suggestions if you upload a sample
  22. Member koberulz's Avatar
    Oct 2006
    Australia
    If I could cut out a sample, I wouldn't have a problem.
    It was recorded in surround sound. I've only got stereo speakers, though, so I can't tell what it's actually playing as. The original file, at least, should be 5.1 though.
  23. Member koberulz's Avatar
    Oct 2006
    Australia
    Worked it out. The channel I was recording from aired the show in 5.1, but the commercials in stereo, which obviously the PVR can't handle or something. I recorded from a channel that airs everything in 5.1, and it worked fine. Was in sync and everything (though it does unsync if I fast-forward or rewind at any point, which could be where others are having problems).
