Hello all,
I've troubles ... My goals are:
- to just extract the h264 and not to change anything on the data to save plenty of time.
- to preserve multiple language audio
The source is taken from DVB-S2, Arte channel, and information is:
Now I'm trying:Code:ffmpeg -i "Andorra HD_4.ts" 2>&1 | tail ... Stream #0.0[0x1842]: Video: h264 (Main), yuv420p, 1280x720 [SAR 1:1 DAR 16:9], 53.74 fps, 450 tb r, 90k tbn, 100 tbc Stream #0.1[0x184c](deu): Audio: ac3, 48000 Hz, stereo, s16, 256 kb/s Stream #0.2[0x184d](deu): Audio: mp2, 48000 Hz, stereo, s16, 256 kb/s Stream #0.3[0x184e](fra): Audio: mp2, 48000 Hz, stereo, s16, 256 kb/s Stream #0.4[0x1857](fra): Subtitle: dvbsub (hearing impaired) Stream #0.5[0x1856](ger): Subtitle: [6][0][0][0] / 0x0006 (clean effects)
and then:Code:ffmpeg -y -i "Andorra HD_4.ts" -vcodec copy -acodec copy Andorra4.mp4
There are multiple errors:Code:ffmpeg -i "Andorra4.mp4" 2>&1 | tail ... Duration: 00:27:07.07, start: 1.000000, bitrate: 1800 kb/s Stream #0.0(und): Video: h264 (Main), yuv420p, 1280x720 [SAR 1:1 DAR 16:9], 1762 kb/s, 7.35 fps, 50 tbr, 50 tbn, 100 tbc Metadata: creation_time : 1970-01-01 00:00:00 Stream #0.1(deu): Audio: mp2, 48000 Hz, stereo, s16, 37 kb/s
- bitrate is incorrect
- fps is wrong (Both video and audio)
- my player refuses to play it
Audio can be kept like this:
but for the video troubles I have no solution. Can anyone help?Code:ffmpeg -y -i "Andorra HD_4.ts" -vcodec copy -acodec copy Andorra4.mp4 -map 0.0 -map 0.1 -strict experimental -newaudio -map 0.3
Thanx in advance
Dirk
Results 1 to 1 of 1
Possible to fix this FLV/H264/MP4 live stream video?
By tigerb in forum Newbie / General discussionsReplies: 0Last Post: 3rd Dec 2011, 16:05 -
How do I play h264 transport stream (.ts) with AC3 audio on an Xbox 360?
By bubbrubb in forum Video ConversionReplies: 4Last Post: 12th Feb 2011, 16:02 -
Problem converting from MPEG Program Stream to Transport Stream
By vivajam in forum Newbie / General discussionsReplies: 5Last Post: 24th Jan 2011, 05:40 -
Remux H.264 Transport Stream as .mp4 (or other)
By Maddux in forum MacReplies: 7Last Post: 2nd Jun 2008, 14:41 -
Extract problem dolby audio from transport stream
By DVWannaB in forum Video ConversionReplies: 7Last Post: 17th Aug 2007, 23:35
