Im using VideoRedo 4.2 and attempting to cut out the commercials. Firstly my apologies if this question has already been answered but I can't seem to find it. So, it's pretty easy using ad detective to find the commercials, but when I click "save as" (usually trying to save a h.264 mp4) the resulting file is 1) realtively small, and 2) the scenes are all jumbled up. Am I missing something? please advise...
Thanks in advance.
Results 1 to 12 of 12
Yeah I tried to cut manually, and when I save the video is all messed up and jumbled. Some parts that I didn't cut are cut out and the beginning is displaced to the middle. Has anyone else had this issue at all??
Please don't be insulted but I have to ask...
- Have you told VR whether to remove the segments you select or to keep the segments you select ?
- Are you adding each segment into the join list in order ? -
Not insulted at all. Im missing something and just don't know what. but in answer to your questions: I am pretty sure I am asking VR to remove the segments I'm selecting. They are not in the finished product and they are in the "cut list" to the right.
As for adding to the join list, I did not do that at all.
Basically im just either manually selecting the commercials out or using ad detective. Then I click on "preview" and look at the finished product and it looks fantastic. Then I click "Save as" and it saves. Then I try to view the saved product and it's either missing some parts or it's out of order (e.g. playing segments 4-1-2-3 in that order). It perplexes me... Any ideas? -
After it saves, does it say it had to remove bad frames (normally in red text)? If so, before doing any cuts, do a quick-stream fix under tools menu on the whole video first. Are there missing parts in the quick fixed video (the same missing parts as when you did your save-as)?
Well when i am editing the commercials, I DO get a warning that it needs to be fixed. (Apparently 2-3 of the commercials are in 720x480). I just figured that since I was cutting that out it wouldn't have an affect though.
as a diagnostic, save as mpeg and see if you get the same result. that is ultra-reliable and will indicate whether it's a setting of yours or something more fundamental.
also, posting on their forum will solicit a response from the developers quick smart. they're fantastic, best s/w support i've ever seen in 35 years in the game. -
Thank you Hydra3333 and the1 for the link and information on the beta version. I'm going to try it out and see what happens and if not, i'll post to the forum. Will keep you posted either way...
videoredo takes too long to save ts
By codemaster in forum DVB / IPTVReplies: 6Last Post: 16th Mar 2012, 08:17 -
VideoReDo doesn't Save/Output entire file after editting out commericals
By peter11815 in forum EditingReplies: 1Last Post: 19th Sep 2009, 15:41 -
Problem with script to cut commercials
By mierdatuti in forum Newbie / General discussionsReplies: 3Last Post: 13th Oct 2008, 01:43 -
VideoRedo:save as VOB disapearance?
By themaster1 in forum Video ConversionReplies: 6Last Post: 3rd Sep 2008, 11:42 -
Videoredo Cut a Single Frame ?
By acestu in forum EditingReplies: 4Last Post: 3rd Sep 2008, 10:06
