The pause key is missing... I see play, stop, record, backward and forward, but no pause.. Perhaps it is hidden, so tell me how to bring it up if what. So i can not stop the file where i want in order to split it - i have to guess where to put the cursor key in order to split it...
never heard of that program but the space bar is used for pause in most audio programs.
a lot of editors work the same way
try hitting the spacebar or the enter button
drag the playback bar down the timeline (scrubbing) to find a point
look under menu>file or view to see if there's a pause listed next to play and stop
there's a magix forum...try there
if all else fails, read the directions...especially keyboard shortcuts -
Magix Movie Edit has no "pause" button either....sometimes annoying. Hopefully their audio editor has the same "zoom" type function where you can really zoom in to look at the waveform.
Magix Music Maker - function to split vocal tracks?
By Artas1984 in forum AudioReplies: 4Last Post: 11th Sep 2011, 18:52 -
Free Music/Beats Maker Software
By mlong30 in forum AudioReplies: 3Last Post: 12th Aug 2010, 09:04 -
video in my Windows Movie Maker project was missing an audio channel
By DaneClark in forum Newbie / General discussionsReplies: 0Last Post: 7th Aug 2009, 19:52 -
Dropped frames when importing Windows Movie Maker video into Magix edit pro
By gom in forum EditingReplies: 1Last Post: 27th Oct 2008, 10:55 -
LG RH387-M Missing Weekly function for Timer Record?
By EmperiumXX in forum DVD & Blu-ray RecordersReplies: 2Last Post: 8th Jun 2008, 15:07
