Hi guys,
I have a little bit of a strange problem with Adobe Encore.
I want to create a home DVD with menu that is playable in both DVD Player and pc with windows media player (this is most used in my country).
I did the project with this settings:
DVD - Pal
Transcode MPEG 2
and build it as an DVD Image with All Regions selected.
I mout that image in some image mouter and it opens up the dvd in Power DVD 11 (which is the default DVD player in my PC)...everything works fine in Power DVD.
But i try to open it in Windows Media Player and i get this error:
I tried then to change the settings ... i changed it form PAL (i am in Europe) to NTSC ...same thing: plays in Power DVD, get the error in Windows Media Player.Windows Media Player cannot play the DVD because the disc prohibits playback in your region of the world.
You must obtain a disc that is intended for your geographic region.
The strangest thing is that i have an older project, i build the disc image, mout in in Magic Disk and i am able to play it in WMP with no errors.
It drives me mad not knowing what did i do wrong....
By the way: i used in timeline mp4 videos, then wmv, and the result is the same...the DVD won`t play in Windows media player...
...and my OS is Windows 7 64 bits
I want this dvd to be playable in WMP because i intent to give the DVD to many of my friends, and i don`t want to tell each one of them to buy Power DVD or other dvd player.
I just hope someone will answer this thread, because if nobody will...i think i`ll break down the damn pc...
Thank you
Yes i tried it on a laptop that uses the same os (windows 7)...i got the same error. ..and the old DVD that i`ve made a month ago is working.
i thougt so myself...but i had to ask.And it has nothing to do with pal or ntsc.
i did that...i know that Europe is in region 2...but when i build the dvd image i chose "All Regions"...so i don`t know what am i doing wrong.Try google for encore region coding.
Is the strangest thing how the old DVD, made with the default settings is working just fine with WMP and any other dvd i make now gives me that error.
Thanks anyway for your reply.
VHS-C playback issue, playback in B&W and distorted/noisy colour.
By jpoel in forum Newbie / General discussionsReplies: 4Last Post: 11th Aug 2010, 09:36 -
DVD Playback Issue
By PB57 in forum Newbie / General discussionsReplies: 1Last Post: 6th Jun 2008, 19:45 -
Jerky Playback (as if disk was scratched!) on a newly made DVD (From AVI)!
By xxjustinukxx in forum Authoring (DVD)Replies: 5Last Post: 10th Apr 2008, 08:23 -
Magnavox MWR10D6 choppy dvd playback when using other home made dvds
By heatherval in forum DVD & Blu-ray RecordersReplies: 4Last Post: 27th Dec 2007, 09:59 -
Playback of DVD Made on a Philips 3400
By Ensign in forum DVD & Blu-ray RecordersReplies: 2Last Post: 5th Sep 2007, 08:35
