  1. Hi i am trying to burn in the soft subs into hard subs using virtualdubmod.. But the program crashes whenever i try to open a mkv file.. any other way around it??
    Or is there a program which can burn in the hard subs while converting it to mp4 for my itouch??
  2. Member AlanHK's Avatar
    Apr 2006
    Hong Kong
    Try VirtualDub, the "Mod" version is quite old.
    Or Avidemux.
  3. Anonymous
    Guest
    indeed use virtualdub instead and use the mkv import filter. this allows to open/import mkv files in virtualdub
  4. where can i dl the filter??
  5. VirtualDubMod's MKV support is very outdated -- based on very early versions of the spec. Don't count on it opening any MKV files but those it made itself.
  6. Anonymous
    Guest
    Virtualdubmod doesn't support the fcchandler mkv plugin.
    starting at virtualdub version 1.8.1 and higher.
  7. DECEASED
    Jun 2009
    Heaven
    [ nevermind ]
