Well, setting PAR is not near as easy as with FFMPEG and Mencoder... but I really like the results of HandBrakeCLI.exe
Could someone post examples of setting the PAR to 16:9 and 4:3 (NTSC if that matters).
A brief explination of how it is set, and how the numbers are calculated would be helplful.
Ive gone through the docs and google to no avail, several switches have been tried but I cant seam to get what I want.
Original media is 720X480 (D1), outputting to the same...
Thanks much,
Andrew
Just FYI, 720x480 NTSC DVD has only two DARs: 16:9 and 4:3. That equates to 32:27 and 8:9 PAR. Or, if you want to assume ITU aspect ratios (often used for analog video tape sources), 40:33 and 10:11 PAR. If you crop black borders away from the edges of the frame the PAR doesn't change. So it's easy to specify the PAR, you only need to know if the source DVD was 16:9 or 4:3.
please explain SAR/DAR/PAR
By shun in forum EditingReplies: 7Last Post: 12th Oct 2011, 11:05 -
PAR and/or DAR prolem, not sure which
By fatcharlie in forum Video ConversionReplies: 3Last Post: 26th Apr 2011, 16:48 -
lost with par, dar etc
By kkiller23 in forum DVD RippingReplies: 12Last Post: 17th Sep 2010, 00:05 -
Video DAR vs PAR
By tb582 in forum Newbie / General discussionsReplies: 7Last Post: 28th Apr 2009, 14:04 -
XviD - Resolutions PAR - DAR
By Cunhambebe in forum Newbie / General discussionsReplies: 12Last Post: 31st Jan 2008, 00:15
